Odd Part found
C5er
Wisconsin
2018 JLU Rubicon
While removing the center panel under the steering wheel to install a Taser mini this part fell out- any ideas of what it is? 2021 JLUR.
Jeep Wrangler JL Odd Part found odd_part
Reinen
2021 Jeep Wrangler JL Rubicon
Looks like it was meant to be pulled off of something during assembly. Mistakenly dropped and left in your dash.
That would be my guess. That sort of thing isn't all that uncommon.
Wbino
NJ
You'll find out on your first turn if it was needed.
John VonJeep
Middle of Nowhere
Many
It's nothing. Totally not mine. I totally didn't borrow your Jeep the other night to pick up chicks and forget I left that in there. Nothing to see here.
Sparty
SW Michigan
04 TJ, 21 JTR, 21 JLR
Congrats, you got a Friday build. Lmao
THIS
You might want to check your door alignment and look around to see if any screws were missed ;)
(Full disclosure, we determined that my old TJ was most likely a Friday build (or Monday after the superbowl) - it had some ummm...minor discrepancies.)
mellophonium
Ralph
Bowling Green, KY
2022 JL Sport 2021 Grand Cherokee L
Another vote for something left over from assembly. I found a couple of the plastic glass alignment tools they use for the hard top inside my JK.
bohnster
Franklin, TN
2021 JLU Sahara Altitude GCM
Bourbon Taster
Bypass line. You'll need some pliers and a set of 30 weight ball bearings...
Jeep Wrangler JL Odd Part found Screenshot 2022-06-12 132717
