New 3.0 Power/Options device!
Mike@Powerteq
Mike@Powerteq
Summit Sponsor (Level 3)
Sanford FL
www.superchips.com
16 JK, 21 JL 3.6L M6, 22 Wagoneer 3.0TT
Senior Product Manager – Domestic Tuning at Holley
Get the FAN OVERIDE onboard and I'll take one. The fan control is an ABSOLUTE must with these little motors...
Done!
Now that looks enticing. Add in a manual e-fan control like the Tazer does and you’d really make this hard to resist….
A new update was released today to add fan control to the app :)
Thanks!
AC77
AC Abegian
Los Angeles
Autobody , singer-songwriter
Interesting, if i may chime in, why would one get rid of the Banks Derringer and go with this one ?
Im very curious, most piggy back tuners, intercept the fuel and boost input, unless its a stand alone
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
There are multiple advantages offered by the Pulsar XT:
1. Pulsar XT allows for throttle sensitivity adjustments, independent of power level.
2. Pulsar XT offers start/stop disable.
3. Pulsar XT offers Tire size adjustment.
4. Pulsar XT offers manual fan control.
5. In our testing, Pulsar XT made more power and torque than the competitors product on the same truck, on the same day.
6. Our power gains are evident at all times, the competitor product doesn't add power until you are at 50% throttle or better.
Thanks
rcliff1
Robert
Cypress, TX
2000 tj, 2014 Mustang GT, 2017 Ford F350 Dually, 2020 Diesel Rubicon on order
Since its for the diesel only, can you put in winch mode (hi idle setting) that another product can't seem to get working.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
This feature is already there!
AC77
AC Abegian
Los Angeles
Thanks
Interesting, thank you !
Plongson
Paul
So. Utah
2020 Wrangler Rubicon JL Diesel, 1984 Jeep Cherokee XJ
Retired engineer and business owner. Vibration analyst, reliability specialist.
So if one was to remove and "divorce" ones JL from a Tazer JL, is your unit going to replace it seamlessly?
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
I don’t see any reason why it would not.
roxj
Cypress, TX
2018 JL Sport S
Is the app compatible with CarPlay so it can be used on the Jeeps infotainment screen.
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
That is not currently an option unfortunately.
Ratbert
PNW
2022 AEV JL370 JLURD
Software Engineer
You'll need to re-enter things like tire diameter, diff ratios, etc.
Hopefully the two can coexist so you can still have things like HomeLink working after turning off your Jeep, turn assist, programming the buttons on your steering wheel, etc.
BAKNBLK
Nevada
JT diesel
Question the Dyno sheet you posted was on a tire Dyno so actual HP/TQ to the ground?
I assume with stock tires?
This was done in 6th gear?
Mike@Powerteq
Mike@Powerteq
Sanford FL
www.superchips.com
Yes, power at the wheels.
I cant say for sure the vehicle had stock tires, but will try to confirm. Not sure on 6th gear as there's usually a speed limit issue at those speeds, but will confirm.
