Need some suspension advice
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
So you’re saying basically, swap the spacers for springs ?
Lifting 2.5" I would have definitely purchased & installed all new coil springs, yes. A coil spacer may still be needed for leveling, after market steel bumpers, winch, rear tire carrier, larger heavier spare, etc.
DeBen21JL
Dennis
2021 Jeep Wrangler Sahara
And this has to do with my jeep pulling to the right because ?
Flip
Johnny
Virginia
Of course the geometry still needs to be corrected. Track bars or relocation brackets and I would prefer adjustable LCAs with 2.5" of lift to correct the castor angle.
DeBen21JL
Dennis
[/QUOTE
thanks
Flip
Johnny
Virginia
I'm necessarily diagnosing your steering issue, just giving some friendly advice. Did it pull to the right before you installed 2.5" coil spacers?
DeBen21JL
Dennis
When I purchased at the dealership it had the same pull, it took them several hours on the alignment rack to fix, but they did fix it. Then we installed the lift and the pull was back. We installed geometry brackets and a front adjustable track bar and a rear track bar bracket, re aligned and still pulls right.
Flip
Johnny
Virginia
Right on 👍
Now see I didn't know you had installed all of that new hardware and still had the same problem.
Jeep Wrangler JL Need some suspension advice th-3784331293
DeBen21JL
Dennis
Right on 👍
It started as a cheap lift, now it’s a cheap lift with some stuff. Looks great rides great just need this steering issue resolved.
Flip
Johnny
Virginia
And I'm not one to scream " it's the RC lift " even though I had ran some RC parts on my TJ and they failed. A lot of people use them and they're fine.
DeBen21JL
Dennis
At this point, the only part of my lift that’s RC are the spacers The sway bar extensions and the adjustable track bar
DeBen21JL
Dennis
Update, had the alignment shop realign and we are very much more drivable. Still a slight pill to the right likely road crown more then anything but the drive is much better. Still a little dead in the center and a little wonder but likely what to expect on 35s. Appreciate the help everyone.
Flip
Johnny
Virginia
That's good, I'm glad you got it straightened out. 👍
DeBen21JL
Dennis
So, in conclusion based on my experience, using the rough country or any 2 inch + spacer lift with shocks and sway bar extensions, will hugely benefit from the front control arm geometry brackets, rear track bar bracket and an adjustable front track bar or bracket.
I used:
2.5 inch RC spacer lift with n3 shocks
- $325
JKS 6102 Geometry Brackets
- $189
TerraFlex 1953600 rear Track Bar Bracket
- $115
Rough Country Adjustable Front Track bar
- $149
$778 total
Could have had a better lift for sure but would have likely been at least double the money. Not a bad set up for a mall crawler.
The key was a good alignment.
Only regret is not just getting the springs to make it more complete of a kit but it rides like stock so can’t complain.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
I used:
- $325
- $189
- $115
- $149
$778 total
Did you happen to get the printout? Be interesting to see what it was.
