My Air Compressor Kit
Larrymuld
Larry
Huntingtown
2020 JLU Rubicon
Good afternoon,
When I got my Smittybuilt air compressor I knew there was a few things that I needed to change right away. 1st thing was to get rid of the flimsy bag that it came with and decided to put it in a tool box. I spent few weeks looking around the web for a big enough tool box that was strong and not too expensive. The second thing I need to do was change the fittings from the Chinese fitting it came with and make them standard. Here is a list of things I used with links.
Smittybilt 2781 5.65 CFM Universal Air Compressor:
https://www.amazon.com/gp/product/B004K25GMG/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
YOTOO Heavy Duty Air Compressor Accessories Kit 20 Pieces with 1/4 inch x 25 feet Polyurethane Air Compressor Hose, 100 PSI Tire Inflator Gauge, Air Blow Gun and Air Hose Fittings:
https://www.amazon.com/gp/product/B07GC4XBYS/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
Air fitting 5/8 hose to ÂĽ standard fitting
DEWALT 24 in. 1-Touch Latch Tool Box:
https://www.homedepot.com/p/DEWALT-24-in-1-Touch-Latch-Tool-Box-DWST24082/202710560
txj2go
DFW
This is interesting, I just bought that compressor a few weeks ago to use on a trip. It works well, the fittings are cheesy and switching them is a good idea.
Larrymuld
Larrymuld
Larry
Huntingtown
2020 JLU Rubicon
It was easy to switch out, I used it every day at the beach going from 20 psi to 36 psi on stock JLUR tires it used took about 7-10 minutes from time of setup to finishing 4 th tire.
txj2go
DFW
Do you have deflators? I think that is my next purchase.
Last we did air down/air up about 5 times. I learned that I could time the deflating with my watch and get close, but this wasn't accurate and over time I had a few tires that were farther away and when airing up using my watch I would end up below 36. Deflators would help to keep things uniform.
I just saw another thread where someone created a manifold of 4 hoses so they could air up all tires at the same time, to the same pressure. This might be a lot of stuff to carry but it would also be convenient.
Another thought I had- using the pump like I did it would be convenient to have a hand-held switch that I could carry from tire to tire.
More things to think about before my next trip in 6 weeks or so.
ConqSoft
Keith
Wake Forest, NC
2020 JL 2 Door Rubicon 6 Speed
Systems Analyst
RE: Deflators: I’ve done a lot of research and it seems that the low priced ones are pretty useless, so I went with the ones linked below. Arriving Sunday so I will be doing some testing to see how they perform. Easy return if they don’t live up to their reputation.
Staun Automatic Tire Deflators (Standard Duty 6-30 PSI) https://www.amazon.com/dp/B00QBPBLWY/ref=cm_sw_r_cp_api_i_2pQ.Eb2T270WX
Larrymuld
Larrymuld
Larry
Huntingtown
2020 JLU Rubicon
I just used the inflator that came with the kit and left the hose off. It was easy to pull the trigger and release the air, I would just release trigger to check the pressure. I found that the gauge was within 1psi then what the system read.
ConqSoft
Keith
Wake Forest, NC
Systems Analyst
Yes that’s basically what I have done in the past but that’s time consuming. I want something I can just screw into each tire that will take them to the desired pressure all at the same time.
txj2go
DFW
I had a pointed tool in one hand and a gauge in the other hand. It would take about 2+ minutes per tire plus checking pressure several times. The worst thing was that I had to be down on the ground doing it. With deflators it seems that you just screw them on, wait a few minutes and take them off.
This is the cheapest that I found that looked reasonable:
https://www.amazon.com/Rugged-Ridge...utomatic+Tire+Deflators&qid=1593571026&sr=8-9
Burt
Burt
Phoenix Arizona
2019 JLUR, 2014 FJ Cruiser (TTUE), 2016 Camry XLE (wife’s)
Previously had that Smittybuilt air compressor, it died and replaced under warranty, the replacement died with
in a few months. Gave up on Smittybuilt and got a Viair 440P, works great..
For deflators, I use the JT Brooks pro, a bit expensive, but easy to set and forget.
bryan
Bryan
Mini, F250, Forester, 2019 JLUR
Regarding deflators...
I have these, and they are great. Very high quality, and couldn't be easier to use. I likewise got the 6-30 psi model; they were preset to 18 psi as advertised. Since I haven't done any hardcore off-roading, I just left them at the preset so it's been totally painless. But there are videos showing how easy it is to adjust the set-point if you prefer a different pressure. I'm thinking about a second set so I can have a set for 12 psi and a set for 18 psi.
ConqSoft
Keith
Wake Forest, NC
Systems Analyst
Good to hear! Mine will be here tomorrow and 18 will be fine for my needs as well.
MexiGo JL
Nuevo Leon
2019 JL Rubicon
Good afternoon,
Thanks for the list.
Do you have any pictures to see how the whole thing came together?
Larrymuld
Larrymuld
Larry
Huntingtown
2020 JLU Rubicon
I will take some new pictures tomorrow.
