ARB Compressor with MORE mount write-up
TroyBoy
TroyBoy
Troy
Vancouver Island, Canada
This would be simple. Aux 1 sending 40 Amps to the pressure switch wouldn’t be a prob? And nothing needed with the blue pressure switch wire?
The dark blue from the pressure switch and the relay is still needed. The red and dark blue trigger the relay and allows power from the battery to get to the compressor motor.
Edit: and it is not sending 40 amps to the pressure switch/relay. It draws only what is needed to flip the relay. Probably less than 1amp.
Mrbiggerstaff
Ben
Boise
‘18 JLU Rubicon
There’s the small black coming out of the relay also. Do I need to rewire that back in and ground it or no?
TroyBoy
TroyBoy
Troy
Yes. All the wires for the relay need to be used.
Mrbiggerstaff
Ben
Boise
‘18 JLU Rubicon
That worked. Thanks. Didn’t have to go to the battery. Red power wire and red pressure switch to the Aux 1. Ground and small ground from relay to same kick plate frame bolt.
Wish I figured it out before cutting up the harness! But I learned a lot. Thanks.
KinderMojo
Adel
United Arab Emirates
Wrangler Jl Sport S. GMC Sierra, Mercedes G63
Engineer
Firstly, thanks a lot for the write up, it helped a ton since the instructions from the MORE bracket were next to useless and there are no youtube videos up yet.
I've done everything but need help with the switches. I wanted to use the switch on the bracket instead of using one of my AUX switches. I tested the compressor by connecting the purple plug to the aux switches and all worked fine but doesn't work with the arb switch on the mount. (I discarded the whole harness and only using the plug with the purple wire)
TroyBoy
TroyBoy
Troy
Hmm, going based on memory, it should be as simple as running your power source to the switch and then the other switch lead to the purple wire but I can’t remember what that switch looked like since I tossed it.
KinderMojo
Adel
Engineer
Ya that's what I was guessing, does the power source come directly from the battery or can be from anywhere??
TroyBoy
TroyBoy
Troy
The power for the purple wire is low amp so it can come from anywhere. It’s just for flipping a relay inside the compressor.
KinderMojo
Adel
Engineer
Thanks a lot, tested everything out and worked perfectly, now just need to finish up..
mike_b_81
Iowa
2019 JLUR
@TroyBoy can you comment on how well the compressor itself works? How long does it take to air up a tire? I’ve been looking at compressors and CO2, the thing with CO2, if you’re away from a place to fill a tank, you’re SOL.
Martindfletcher
Martin
San Diego
Ducati 1299s, 2018 JLUR
I can fill 4 37’s at once from 15 to 30 psi in a few minutes near sea level and around 5 minutes at 6000’. I didn’t time at altitude, but I had 3/4 beer left.
mike_b_81
Iowa
2019 JLUR
That’s really good timing! I think this might be a winner.
