TroyBoy
- Troy
- Jun 14, 2017
- Vancouver Island, Canada
- 2018 JLUR
I just started building my under floor storage. Only one pic so far but I will post more tomorrow. First step was to pull out all the carpet in the back to get it out of the way. I also pulled out the tie downs. I’m going to use the bolts to secure the storage to the body.
You can't see it but all sides are different heights. The only one I didn't have to modify was the left side.
I found some metal brackets at the hardware store and modified them to take the original tie-down bolts. Some of them also had to be shortened to clear the basket. There are 4 washers each underneath the right side brackets because that side sits on top of the plastic. The brackets on the left side have 1 washer each.
It was a bugger trying to cut out a template for the top.
Here it is complete. I plan on removing it and having it sprayed with Line-x.
This pic shows how close I got to the tailgate
Last time I made one of these I put the piano hinge in between instead of the outside but I find this much harder to line things up.
I added some latches. I had to fabricate my own top clip because I couldn't find any with a 90 degree bend.
I finally finished the project with a hydraulic lift
