Mopar Lift Kit vs....
Pig-Pen
Banned Camp
2018 JLU
jabroni
Look at like this... with the mc 2.5 rocksport, its one and done. You’ll have a lift that rides great and when you start doing more off-roading ( and you will at some point) you’ll have one of the best lifts on the market under your rig. It’s better to have it and not need it rather than need it and not have it. This goes for rock krawler as well.......:)
i was checking out the MC 2.5" kit and they highly recommend replacing the driveshafts due to their shock mount relocation. unless i was reading it wrong or something... if you dont have to replace any driveshaft parts, then its certainly a good package/deal.
Roky
Roky
Yeah...mc and rk are extremely flexy. I replaced my front drive shaft back when I still had my Mopar lift on. The collar at the transfer case was getting all mangled up. I would recommend replacing driveshaft with either of these kits. It really depends on how your going to be wheeling it really. That would determine the urgency imho......:)
apb
Andy
Huntersville, NC
2020 Sting Gray JLR; 2019 Bikini Sahara JLU (wife's)
I went with the Metalcloak 2.5” lift with Rocksport shocks. It’s really good however it does feel a bit stiff. I don’t have a problem with it tho, makes the steering a bit more firm
Did you replace your front driveshaft? If so, did you go with theirs or another brand?
jlroman2
Jorge
Chicago, IL
2018 Jeep Wrangler JLU Sahara (Granite)
BCBA
I didn’t but was planning on doing so soon. Unfortunately, I was one of those with the noise in the rear axle so it’s been in the dealer for two weeks. Once my rear axle gets replaced, I plan on replacing the driveshafts. Probably will go with Adams. But tbh you should be good if you go with the ones MC recommends.
Roky
Roky
I’ve got the Adams, been in for almost a year, no issues, works great. The rear is still ok, I’m gonna wait until I have to before I switch it out......:)
Jeep Wrangler JL Mopar Lift Kit vs.... D74FCA48-C3A6-4E28-9084-F21F1CAF2334
2020 Jeep Wrangler Sport JL
Warranty or not, I still feel like the problem with the Mopar lift is it is marketed as a 2" lift however lifts nearly 3" and many times you need more geometry correcting parts to correct it. Axles will be off and some people (like me) needed to add caster to correct driveability. Consider adding $600 on top of that to have everything square enough, if not more.
Here is my issue so far. Bought used 2020 with mopar lift already installed. My caster is way out...2.5 degrees and should be around 6 degrees hence the wandering issue. Took it to the shop and apparently the stock lower control arms are still on it. Ughhh. So I will need to put adjustable LCA’s to fix issue.
My question, the local jeep shop is swearing the way the Jeep stands it must be at least a 4” lift. The dealership parts manager told me it’s a 2” because Mopar did not have a 4” at the time. Any thoughts and is there a way to figure out which I have so I can order the correct control arms.?
hoag4147
Colleyville, TX
2022 JLUR XR
To be honest you will see more like 3.5" lift on a Sport. Even Rubicon folks are seeing more than 2" of lift. If you install Mopar lift LCAs you will still be under recommended caster, so get a decent set of adjustable LCAs.
RubiRob
Rob
Hampshire, IL
24 F-150 Raptor
Janitor
The mopar lift sits higher than advertised and even more so on a non rubicon. I would recommend getting a set of front and rear track bars and front lower control arms... the arms as the bare minimum. You can get an adjustable set pretty cheap and maybe even in the used marketplace here on the forum.
Thanks for the reply. Update, I found the jeep dealer who did the install and will be bringing it to them next week. Might be a battle. They say the lift kits lower control arms look exactly like the originals which I don’t believe. Mine are shaped like an I-beam and I think the lift kits are tubular. If anyone has a pic of their mopar lift kit lower control arms please send pic so I have more ammo to have them repair at their cost. Thanks
Thanks for the reply, this forum is awesome. I’m a jeep newbie but getting schooled.
RELBUS
Chicago
97 TJ , 22 JLURXR 392
The arms look exactly like stock, only slightly longer. They are correct in what they are telling you.
And the mopar kit does sit tall.
RubiRob
Rob
Hampshire, IL
24 F-150 Raptor
Janitor
They looked exactly the same as my 2018 JL stock arms just about 1/4” longer
Thanks for replying that helps.
Does anyone know why it would leave their shop with the caster angle at 2.5 degrees instead of being around 6 degrees? On the phone they’re telling me they do an alignment post install. Just trying to arm myself with knowledge.
They also suggested it might need a caster/camber bolt kit to resolve problem which really has me concerned about this dealership.
Roky
Roky
Hi John,
It’s the amount of lift you got, is the reason for your low caster. Looking at your avatar pic it looks like you got more like 4 inches. Can you measure your front axle like this.....
Jeep Wrangler JL Mopar Lift Kit vs.... FDBC41C0-52F3-421C-8F87-1084124B05F8
Jeep Wrangler JL Mopar Lift Kit vs.... 6CE4A074-6B7C-45EB-8BDE-A6A6CD872D4B
I’m curious how far your axle is off center. The sport in these pics was off 1 inch after Mopar lift install. What part of Florida? I’m in Citrus Co.
hoag4147
Colleyville, TX
2022 JLUR XR
2.5 seems low even for stock. If they would have put mopar lift arms on I would think should be around 5. Anything higher will require adjustable LCAs. Good luck
