Mopar Lift Kit vs....
2020 Jeep Wrangler Sport JL
Honestly, save your sanity and just spend the $200 for a set of adjustable front lowers. You can get caster pretty well with a digital angle finder doing it yourself
Your probably right, just trying to save $, I’ll see what dealership says next week and hope they will do the right thing. Thanks to all on this site, you guys are incredible.
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Rrr
This is the number on mine, different than yours
Definitely not the Mopar Lift LCAs :facepalm:
If they are paying then have them install the ones that go with your lift. unbelievable...
I suggest just go the route Rob mentions above and get some adjustable LCAs now and be done with it.
RubiRob
Rob
Hampshire, IL
www.instagram.com
24 F-150 Raptor
Janitor
I hear you. I’m just a massive pessimist with dealerships. They’re worse than ever before here in Illinois.
Roky
Roky
Hey John, if you can’t get anywhere with your dealership and need a hand, just holler at me. We can get you dialed in in a couple hours.
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
To be honest you will see more like 3.5" lift on a Sport. Even Rubicon folks are seeing more than 2" of lift. If you install Mopar lift LCAs you will still be under recommended caster, so get a decent set of adjustable LCAs.
do you think driveshaft needs to be replaced too with the mopar lift kit on my sport JLU
hoag4147
Rick
Colleyville, TX
2022 JLUR XR
Depends on use but I believe you will be fine with stock.
Roky
Roky
As long as you use the shocks that comes with the kit, you’ll be ok . It’s not the lift height, it’s the extended length of the shocks that determines if you need aftermarket driveshaft.
JeepBear
Richmond, VA
2021 JLR
I’ve heard with 2 dr wranglers, if you have enough lift the rear drive shaft will be in a constant state of pinch because it’s so short and it’s a good idea to replace it. Not sure if the mopar 2” gives enough lift to cause this, can anyone confirm or refute that?
Roky
Roky
I’ve only installed a couple Mopar’s on 2 doors, they both netted just under 3” . There are some on here that got closer to the advertised lift height on there 2 drs. IMO, 3” is max you should go on 2dr without addressing the driveshafts. Maybe check with @OnlyOne , he’s rockin the Mopar and 37s on his 2 dr.
