"Max A/C"
Vinman
Vince
Calgary, Alberta
2021 JLU Rubicon
If I thought my A/C wasn’t keeping up the first thing I’d try is removing the cabin air filter and tossing it in the trash
I opened a window and the vent air volume really jumped. A year ago, I installed a tailgate table that blocked the vented tailgate.
AFD
Northeastern US
2023 JL Rubicon (2DR/V6)
Did you try putting your softtop/hardtop back on? 😆
But for real, when's the last time you replaced your cabin filter?
Do you have jscan? I do. On record and speed 3 my evap temp, as shown in jscan, is 42 degrees when outside temps are above 95.
Got it. I'll fire up jscan.
There's a cabin filter? I thought those were only on goochi cars with mood lighting and those have "lifetime" filters
  • Haha
Reactions: AFD
AFD
Northeastern US
Fair enough! Think my JL is only the second vehicle I've owned that's had them. Heck, my dad's JK Sahara had the enclosure, but shipped from the factory without a filter installed at all.
Imma get a snorkel for mine. High-flow HVAC for the win! 😂
It's likely my cabin filter is responsible for carrying off a good portion of the dirt missing from the Rubicon trail and some Moab and Big Bear trails. I haven't looked at it since starting rock crawling a couple years ago. Also, I noticed the Jeep is leaning slightly on that side where the filter is.
Wabujitsu
Sarasota, FL
2021 JLUR, 2020 JLU Sahara
Retired US Army
Is it possible you’re just having hot flashes?😉
Hmmm. I'm gonna check all my medications to make sure my wife didn't mix up hers with mine.
arnie_mueller
Arnie
Castle Rock, Colorado 80104
Thanks for all the replies. I found out what everyone stated by driving it and trying it.
Can I trouble some of you to toss a thermometer in your center driver side vent and run your system on Max next time you drive it and post the temperatures here? I can't get below 44-46F. My truck and my wife's car (both R134a systems) get noticeably colder.
Give me 90 minutes and I'll get on this after my next meeting. I need to go to the store to get some cilantro and jalapenos for my guac anyway. I have one of those infrared thermometers. By noon it should be 90 here and sunny here.
Thank you
If you have a regular meat thermometer, I think that would reflect more closely to the air temperature.
Jeffy56
Payson, AZ
2018 Wrangler Unlimited Sport
Lately the coolest output is close to 40°F center passenger vent. Ambient 94-98°F. Recirc on, 5000'. Recirc should give slightly higher fan out with a clean filter. I've rebuilt and/or upgraded a R12 and a couple of R134 systems. I would suspect the 1234 system will operate at higher pressures. My cabin air filter has been changed twice in 1 1/2 yrs and 14K miles. I'll check calibration of the analog thermometer, which was a good grade unit. My overall view of the system is it's marginal. I will run the "max cooling fan" Tazer option when I'm near the next destination. 2018 JLUS, 3.6, 62K miles. Calibration is good, as seen in last pic.
Jeep Wrangler JL "Max A/C" 20240820_092620
Jeep Wrangler JL "Max A/C" 20240820_094349
arnie_mueller
Arnie
Ask and ye shall receive
Thats running i
Thank you
Running it for 25 minutes in a drive to the store
Jeep Wrangler JL "Max A/C" IMG_2481
