Main Battery/ replace.
stlyrfac
new england
2018 Wrangler Sport S
I need some assistance from here, I removed small negative cable and pulled fuse #42, jeep lights, electronics came on but didn't start, checked the voltage and it was at 11.6 volts, put the cable back on and it read 12.5 in run mode, not started. So my question is if my main battery is going bad can I just replace it with a new one, or would I have to reset the BMS/IBS. Can I just swap out main batteries? I am deleting my aux also. Did the same thing on wife's jeep and it started.
Thanks
andy29847
Andy
Trenton, SC
2020 JLUR
yes - replace that battery. I like the Everstart batteries found at Walmart. This is from a few months ago so the price will probably be higher.
Jeep Wrangler JL Main Battery/ replace. i-4rrpkhs-X3
stlyrfac
new england
So I don't have to reset the BMS? Just pull the old and put in new?
jludave
The Isle of Long
IT Manager
stlyrfac
new england
Thank you, just don't want to blow shit up and or all the crazy lights coming on after I do it. I have always changed my batteries in my vehicles, easy peasy.
Thanks again
nsfw_andy
2022 Hydro Blue JLUR Ecodiesel
I bought that same one earlier this month, it's like $180 now.
stlyrfac
new england
Correct, 180 at Walmart, just looked. Better than orieilys or advanced, they want 250
stlyrfac
new england
I got in the jeep earlier and start/stop said battery protection mode, then start stop ready now back into protection mode. This jeep is crazy. Going to get that battery later
andy29847
Andy
Trenton, SC
2020 JLUR
Pull fuse 42, disconnect the aux battery, put in the new battery, crank up and go. Your Jeep will now work just like cars have since the early 1900s. BTW, the Walmart Everstart, at 850cca, is almost as strong ar the 2 Mopar batteries together (200Cca, 700cca) plus you get a 4 year warranty.
Bandit59
Tennessee
2021 Jeep Wrangler 4xe
Thanks
. You might lose your settings on your radio and other things. But give it time it will reset
stlyrfac
new england
So I changed the battery, bought the one from Walmart 179.00. Pulled old one put new one in, Pulled fuse 42 and removed negative cable from main battery. All set no issues. Thanks everyone. Also battery now reads 12.8 volts while driving instead of 14.0.
UTME
T
2024 Rubicon-X Unlimited
For newer models add an auto start/stop eliminator for the perfect solution.
Ormond Beach, Florida
Retired at 55 ..
