Locker Position Sensor Potting - DANA 44
Steve JLUR
CoS, CO
2021 JLUR
word302
Oregon
JLU
cavguy
Arizona
2020 JLUR
Well if you look at the illustrations that references the entire ring and pinion kit (item #73). The locker sensor isn't depicted in any of the drawings.
Interesting, the description says its a sensor...
  • SKU:68544629AA
  • Other Names:Sensor
Ospreyfe55
Marc
Navarre, FL
2020 Jeep JLU Rubicon
Well I went back to another diagram and found that the locker assy is listed as #110 but the sensor is listed as #111.
sourdough
left coast
JL-sold
It's about time they offered the damn sensor. What a F'up and issue for many. I didn't want to have an issue so I put a Z harness in the glove box ASAP. It's become time for servicing the diifs., so today I pulled the rear sensor. No oil but potting it anyway. Re-assembly tomorrow. I wish I'd thought out the tube of potting solution a little better. The injector tube will be hard and plugged by the time I tear down the front. The mixing tube looks improbable to clean. FYI, If you are going to do the sensors one at a time, buy two tubes of the potting stuff. Also I was a little apprehensive drilling out the holes and going to deep. For piece of mind, I cut a 1" length of 3/4" wood dowel and drilled the center out so to use it as a depth limiter with the 3/32 drill bit sticking out 1/16", no worries.
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 dowel for depth
Siskababa
Nick
Cave Creek AZ
2018 Wrangler JL Rubicon 4D
The mixing tube cleans pretty easily. I used a squirt bottle with denatured alcohol (home depot) to start cleaning out the tube until it was fairly clean. Then took it to the sink with hot h20 and repeatedly rinsed it out until it was completely clear. I reused the same tip 4x's (long story) without any issues at all.
sourdough
left coast
JL-sold
The paint thinner I tried wasn't the right stuff, even tired the Electrical Contact Cleaner spry can. Gave up and ordered another $11 tube of potting stuff.
Siskababa
Nick
Cave Creek AZ
Was it already somewhat dried? I did the cleaning as soon as I was finished with the tip and it worked every time.
HungryHound
TN & FL
1975 CJ-5, 1983 CJ-5, 1998 TJ, 2021 JLURe
Yeah, I blew mine out with an air gun and it was good for a touch-up the next day.
Jmos4
2020 Challenger Scat Pack M6/2007 Ram 2500 G56
Hi,
Looked this morning for the sensor and almost all came back with "403 Forbidden", wonder if they didn't want the cat out of the bag yet?
1 had a picture:
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 Screenshot_20220114-074754_Samsung Internet
Although it looks different, haven't seen in person.
Regards,
