Locker Position Sensor Potting - DANA 44
Ospreyfe55
Marc
Navarre, FL
2020 Jeep JLU Rubicon
Get the tazer wiring harness and be done with it. Works just like factory.
The harness just masks the issue. It will not prevent your locker from engaging or disengaging inadvertently. This is discussed furter back in this thread.
Dale's Jeep
Dale
Michigan
2018 Jeep JL 4door Rubicon
Retired U.S. Army 23 years
Not sure how to can happen.
Dale's Jeep
Dale
Michigan
Not sure how that can happen.
MSparks909
Miles
NC
JLU Rubicon 3.0
Potted mine today, 1100 miles on the Jeep. 10/10 pucker factor, only had a hand drill. Thank God I drilled *slowly* with light pressure because my drill bit actually made light contact with my rear sensor circuit board when drilling one of the holes…I looked through the hole and couldn’t see any obvious circuit board damage. Before I filled them with potting compound I popped both sensors back into the Jeep to test the lockers in the garage to make sure I didn’t damage the rear sensor. Rolled back and forth about 5’ and…both axles still lock! Talk about a huge sigh of relief!
The sensors are now filled with potting compound and are curing in the garage. Will re-install tomorrow with the new diff covers and I’ll double check function again. Was pretty nervous doing this with so few miles on the Jeep but I don’t want to have a potential issue down the road. This will hold me over until I eventually throw some Dana 60s under the Jeep ?
Ospreyfe55
Marc
Navarre, FL
FYI: Mopar # 68544629AA Sensor Kit, Axle
If that is the right part number and sensor then that is it! I see that haven’t addressed the sealing issue! I would still get a new one and have it potted. That’s the only way to seal it up.
Dave928
Washington
2020 JLU Rubicon, 03 Silverado, 88 Porsche 928 S4
Aircraft Tech
pot it or epoxy the cap real good.
californiajeeping
JLUR
Fastmover
Bob
Ottawa
2019 2.0L Billet JLR: Ordered 1/9. Delivered 2/13. Picked up 3/5.
Googling 68544629AA does not bring up the sensor.
4xFUN
Scottsdale AZ
2024 2-door Ruby-X, 2020 2-door Ruby, 2023 RAM TRX
It may be the correct part but every illustrated exploded parts view on Mopar's site does not show anything resembling the notorious sensor...
Has anyone actually ordered one and can verify this is the is indeed the correct sensor?
Jlhens03
J
Ohio
2022 JLU Rubicon XR
I say we all kick in a little cash each to someone and they order it to see if that’s the one.
word302
Oregon
JLU
It looks like you can purchase the sensor now. BAM parts shows it as #71 in the diagram and refers to it as the sensor. Picture on diagram matches the sensor part. It's about time.
It’s ridiculous that they’re gouging on this poorly designed part.
