Locker Position Sensor Potting - DANA 44
Jasper519
Jason
2019 JLUR
Got it done finally. All tested out and works great. My tape kinda didn’t hold as it should have when I injected the back on one of them, but it fit and works. I’ll just take it as I definitely got the air out.
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 3F4F1370-D2B1-4AD8-A988-BB4F4B241A0E
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 7693CFB1-673C-4D5D-82CD-A121309384E3
Jeep Wrangler JL Locker Position Sensor Potting - DANA 44 3F536FAA-E087-48A0-B815-EFD48DF26130
Steve JLUR
CoS, CO
2021 JLUR
Did you use a drill press? How did you make sure you didn't drill too far in?
rkwfxd
Rich
Whittier
Unemployed
What are folks doing when this sensor fails and they are out of warranty?
rkwfxd
Rich
Whittier
Unemployed
word302
Oregon
JLU
OK so you are saying that IF the sensor fails and the lockers no longer work due to that failure, one could plus the Z “jumper” in and get the factory lockers to work. Even with the oil soaked failed sensor?
Yes, it bypasses the sensor, so you would no longer have a dash indication of the locker position but it would work normally.
limeade
Guy
Reno, NV
Some use the Z locker from Z automotive. I haven’t used it but will if mine fails.
https://www.zautomotive.com/product/z_lkr_oem/
I installed one for the rear axle prior to my Rubicon trip as I hadn't potted my sensors and didn't want any issues while on the trail. The Z Locker worked like a charm and my lockers seemed to lock/unlock quicker. I'm going to add a front Z Locker and call it good so I don't have to do the potting. With my luck, I'd drill too far.
rkwfxd
Rich
Whittier
Unemployed
OK well that sounds pretty good. I have a new Rubi ordered. I work from home so I doubt I would put enough miles on it to fail before the warranty was up.
Im thinking, put a few hundred or a thousand miles on it, change the diff oil, pot the sensors, upgrade my diff covers and call it good. Down the line if a sensor ever fails post warranty Ill just get the Z jumpers and carry on.
Unless the sensors are avail by then.
word302
Oregon
JLU
If you pot the sensors it is highly unlikely that they will fail.
DanW
Are you sure? I swore @Zauto said everything would work as normal. I didn't remember them saying the dash indicators would not work.
Brad41
S. Indiana
18’ JLUR firecracker red
My dealership stated it’s covered under the powertrain warranty, which is longer than the bumper-bumper. You might check into that.
chevymitchell
chevymitchell
Shawn
Pueblo West, CO
Avi Engineer
Dash indication of locked and unlock will work. The "in-transit" function will not work.
You select lockers off, the locker will indicate off, but may not be physically unlocked in the diff.
The harness will work to select the lockers, but will not give you a true indication of the locker plate position. You will have to do that by feel while the Jeep is moving.
Steve JLUR
CoS, CO
2021 JLUR
If the dash is indicating an incorrect condition, either way, what can be done about it? While using the ZAuto harness.
