LCA Bracket Skids
grimmjeeper
Roy
Castle Rock, CO
www.grimmjeeper.com
enginerd
No experience with those but I welded Artec skids on mine and have been happy with them.
Buddy Lee
Victor
San Martin, California
2021 JL Rubicon Unlimited
I have the Hard rock lower skids. They are very stout and can take a hit. The only downside is they are wide and when you install them they pinch inward even with the included spacer. I also don’t like the bolt that comes with it, they rust almost immediately. I would recommend replacing it with a zinc one. Finally don’t follow the included torque values. They are to low. Just follow the factory torque specs which are much higher.
RicRecon
Ric
NorCal
2021 JLUR 3.0, 2021 JT Overland 3.0
I have the Artec skids on my rear LCAs and they work very well
BobW
Bob
Ventura County
2018 JLUR 6sp MT; 2019 GC; 2021 Lego JLR
I like the RH4x4. Pretty easy to install with jeep flat on garage floor. The only hard part (for me) was getting the 190 ft-lb torque given limited clearance to floor. I did have to ratchet strap the front passenger side to pull things in line.
PS--if you want to upgrade the FAD skid, do that first since the LCA will be in the way.
Terrymo
Terry
2023 JLURXR 3.6 ET
Hardrock4x4 front lower control arm skids will require you to modify the Metalcloak FAD skid if you have it. I switched to the Hardrock4x4 FAD skid. They may also also interfere with the newest version of the Next Venture Rubicon front diff skid and require modifying both pieces to have easy access to the LCA skid mounting hardware. As was already said their hardware is prone to rust.
https://www.jlwranglerforums.com/forum/threads/rock-hard-4x4-front-control-arm-skids.45721/
Jeep Wrangler JL LCA Bracket Skids IMG_1452
Jeep Wrangler JL LCA Bracket Skids IMG_1396
Jeep Wrangler JL LCA Bracket Skids IMG_1391
limeade
Guy
Reno, NV
Hmm I'd probably do bolt on. I don't have any way to weld. ?
I have the weld on Artec front LCA skids too. Cost me $30 to get welded on, so it's not very expensive to have done. They are strong and worth it. I went with the Artec bolt on rear LCA/Shock skids and they're also very strong and worth the cost. You won't go wrong with anything from Artec.
SadRobot
SadRobot
Los Angeles
2025 Prius LE
Looks like the Artec are the thickest of the 3. If I went Artec I'd probably paid them black. That grey is just an odd choice.
limeade
Guy
Reno, NV
They're powder coated and the color isn't too bad. Plus, the way they're oriented, the color doesn't stand out too bad.
SadRobot
SadRobot
Los Angeles
2025 Prius LE
I was looking at the Artec website and their disclaimer makes a really good point
"May not install if factory brackets are bent and bashed from rocks."
I checked mine out and their pretty banged out of shape. Are they fixable or am I SOL?
Jeep Wrangler JL LCA Bracket Skids IMG_2080
Jeep Wrangler JL LCA Bracket Skids IMG_2081
Smokey_The_Rooster
Smokey
Earth
Jeep
Watch the Artec video, they show using a screw clamp to get them on. Might work for you as well.
Mx5red
Paul
San Diego
2020 JTR, 2020 JLUR
I'd pay someone to weld on the front brackets. My Rock Hard ones are fine but as said the bolts rust, they won't play well with FAD skid besides their brand, they are hard to tighten adequately.
It may be easier to pay someone to weld than to get the front bolts to 190+ ft-lb yourself again.
I had a "clunk" I noticed when reversing diagonally out of my driveway I finally tracked to these not being tight enough. Re-tightened and now they don't clunk, but still...
