Plan d
Quite a handy little tool.What is an X shackle?
https://www.asroffroad.com/sx-8000h-x-lock-8-000-lb-wll/
The 8,000 lb version is only good up to 7/16" synthetic line, although they do make a 20k lb version it doesn't show a line size limit. At 1 lb 6 Oz, I would not even consider putting that potential projectile in a kinetic pull, not to mention the tight bend radius is tough on your ropes. Nowhere on their site do they recommend it for use with kinetic ropes either. As far as shortening my winch line, the motor does that pretty well? Short of trying to pull something like a sxs out with a hand winch I just don't see the recovery situation it would be useful? Seems like it adds complexity to the rigging, stress to the lines, and a potentially lethal projectile mid pull with very little gain to me.
like any other tool, if you don’t know how to probably use it you are better off not to.The 8,000 lb version is only good up to 7/16" synthetic line, although they do make a 20k lb version it doesn't show a line size limit. At 1 lb 6 Oz, I would not even consider putting that potential projectile in a kinetic pull, not to mention the tight bend radius is tough on your ropes. Nowhere on their site do they recommend it for use with kinetic ropes either. As far as shortening my winch line, the motor does that pretty well? Short of trying to pull something like a sxs out with a hand winch I just don't see the recovery situation it would be useful? Seems like it adds complexity to the rigging, stress to the lines, and a potentially lethal projectile mid pull with very little gain to me.
You posted in the kinetic rope thread a product that isn't designed or recommended for use with kinetic ropes, but I'm the one who doesn't know how to use it...like any other tool, if you don’t know how to probably use it you are better off not to.
I have a 7/8" and the broken one seemed thicker but I can't say for sure.Everyone has made the assumption it's a 7/8" rope? Is that right? If so, find a better class.
That's why I'm astounded someone would use a 7/8" rope for training. How old was that rope?
I got a similar one from GearAmerica. I've pulled 2 stuck vehicles on the beach with it, has worked a treat. Both were larger than my JLR. Also fits nicely in the small rear bin.Well I just pulled the trigger, I mean pushed the button on the Bubba 7/8in by 30ft. 7/8in is rated for 5700lbs to 9000lb vehicles per Yankum website. I haven’t weighed my JLR but I think it is probably in the 4500 to 5000lb range loaded up. Yankum says 3/4in is rated for 3800-5400lb vehicles but also says it’s designed for UTV/SUVs.
Both Yankum and Bubba 7/8in are rated for 28,600lb. I would guess they both source their rope from the same manufacturer.
It arrives tomorrow. The Yankum is back ordered and my impatient self didn’t want to wait. I would be kicking myself if I got stuck before then.
Both net out the same price as the Bubba is off Amazon and free one day shipping. The Yankum is cheaper but shipping negates the savings. Both made in USA.
As far as shortening my winch line, ... I just don't see the recovery situation it would be useful?The 8,000 lb version is only good up to 7/16" synthetic line, although they do make a 20k lb version it doesn't show a line size limit. At 1 lb 6 Oz, I would not even consider putting that potential projectile in a kinetic pull, not to mention the tight bend radius is tough on your ropes. Nowhere on their site do they recommend it for use with kinetic ropes either. As far as shortening my winch line, the motor does that pretty well? Short of trying to pull something like a sxs out with a hand winch I just don't see the recovery situation it would be useful? Seems like it adds complexity to the rigging, stress to the lines, and a potentially lethal projectile mid pull with very little gain to me.
replace it when it shows signs of wear.That rope looks like it had been over used/abused for awhile. Taped up sections indicating prior damage. At least it was his truck that got damaged as that thing should have been removed from use, let alone used to teach a class. Kinetic recovery is likely more dangerous than winching due to the forces involved. You are creating a slingshot using two 5k+ pound vehicles. A 7/8" rope has ~30k lb break strength, that force goes somewhere when it breaks. My 1.25" rope has a 54k lb break strength, of course there will be damage if it is abused until failure. A new windshield alone costs 4x what I paid for my rope, replace it when it shows signs of wear.
Seems I could always combine it with the recovery strap if needing a longer reach. Is that smart?I'm in the market for a kinetic rope. Pretty much decided I will go with the Bubba rope 7/8in for my JLR. Just trying to decide on length. 20ft or 30ft. I'm trying to keep my weight and volume to a minimum. Looking for comments from those that have used one more than a couple times. Is 20ft enough? Seems I could always combine it with the recovery strap if needing a longer reach. Is that smart?
https://www.amazon.com/dp/B007HYR8H...colid=31XGZYX9AVZ7D&ref_=lv_ov_lig_dp_it&th=1
You probably won't need a longer rope, but I don't think there's a problem using a 4" strap rated at 40,320lb Break Strength.OP here… I ended up with this 7/8in by 30ft made in USA:
https://www.amazon.com/gp/product/B007HYR85W/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
No… I’m good. As I mentioned before I am being anal on keeping my gear as light as possible. I want to be prepared (Boy Scout) and still be able to use and tow my JLR and stay under weight limits. As a general comment, I gravitate toward aluminum or composite materials wherever possible. Steel is old school.You probably won't need a longer rope, but I don't think there's a problem using a 4" strap rated at 40,320lb Break Strength.
I have the smittybilt 1in (essentially the same as bubba rope) 30ft and the extra length is very useful. For storage, mine is bigger but it still fits nicely in that gap behind both the driver and passenger seats. I pulled my ranger out a few weeks ago and the extra 10ft made it so I wasn't in mud trying to get a running start on the pull.I'm in the market for a kinetic rope. Pretty much decided I will go with the Bubba rope 7/8in for my JLR. Just trying to decide on length. 20ft or 30ft. I'm trying to keep my weight and volume to a minimum. Looking for comments from those that have used one more than a couple times. Is 20ft enough? Seems I could always combine it with the recovery strap if needing a longer reach. Is that smart?
Ha… we are on the same page. I was able to stuff the rope in its bag in the well behind my driver’s seat. Also a lot of big waterholes around here and I do like to keep my feet dry. If I am pulling a buddy out though, he is doing the wading.I have the smittybilt 1in (essentially the same as bubba rope) 30ft and the extra length is very useful. For storage, mine is bigger but it still fits nicely in that gap behind both the driver and passenger seats. I pulled my ranger out a few weeks ago and the extra 10ft made it so I wasn't in mud trying to get a running start on the pull.
I wouldn't want to mix in a standard strap with a kinetic rope on a full kinetic pull, the strap just isn't designed for shock loading even if the rope in theory will cushion it. Now if someone just needs a little tug, I'll combine every inch of strap/rope/winch line/ tree saver I can round up if need be. Of course if they just need a little tug I'd probably just pull closer to them. Stuck alone, there's no kinetic recovery to be had, but I have run 100' of winch line to my 30' rope to my 20' strap to reach a tree before I started carrying the 100' winch extension.You probably won't need a longer rope, but I don't think there's a problem using a 4" strap rated at 40,320lb Break Strength.
I get that. If you do add standard strap in line with the kinetic rope, the static strength rating needs to be much higher. It’s all about sizing your gear to be appropriate and safe.I wouldn't want to mix in a standard strap with a kinetic rope on a full kinetic pull, the strap just isn't designed for shock loading even if the rope in theory will cushion it. Now if someone just needs a little tug, I'll combine every inch of strap/rope/winch line/ tree saver I can round up if need be. Of course if they just need a little tug I'd probably just pull closer to them. Stuck alone, there's no kinetic recovery to be had, but I have run 100' of winch line to my 30' rope to my 20' strap to reach a tree before I started carrying the 100' winch extension.
