jlur broken visor
Rsarffs
Socal
2021 wrangler unlimited rubicon, 15 rzr xp1000
Jeep Wrangler JL jlur broken visor 20221018_220831
visor plastic pivot point retainer is a weak design (imo) on my 2021 jlur and their are aftermarket plates
Jeep Wrangler JL jlur broken visor 20221018_221629
Jeep Wrangler JL jlur broken visor 20221018_222351
available to address this issue.
cOtter
Southern, Indiana
‘20 Sahara 2.0L Ocean Blue Metallic, Toyota Highlander & Pontiac G6 coupe
Senior Manager PM (Automotive OEM)
I have a ‘20. Both of mine have broken. I used to small brackets that look very similar to your pic to address the issues. Honestly Jeep should change to horrible design or adopt similar CM to address the issue before the Jeeps leave Cleveland.
dchemphill1
Nebraska
2020 Wrangler Rubicon Recon
School Administrator
Yes there are brackets to install(Google it) ..I think $20 and you get 1 for each side. I had my driver side one replaced under warranty and it was like 400 bucks because it has the home link wired in it. I then put the brachets on. Yes jeep needs to have beefier design on a 45+k vehicle.
Roky
Roky
Rsarffs
Socal
These plates I received are a very tight tolerance fit. Use pliers to install...
Jeep Wrangler JL jlur broken visor 20221019_162811
c20040215
Leon
The hinge itself is not a design flaw. It is the visor shape at the corner where I circled. When visor is down 2/3 of the way it blocks your view so natural reaction is to push it towards the windshield as much as possible. In that case, the corner hits the A pillar/windshield trim and crates a levage force that wants to pull the hinge out, which is not the motion it was design to do.
The reinforcement could make it stronger but the interference is still there every time you try to swing the visor all the way out closer to the windshield.
NeilP
Neil
South Dakota
2024 Jeep Wrangler Sahara Unlimited
RETIRED!
I just missed the warranty expiration date. Cost me $38 bucks for a new one and $35 for the kit to fix it so it never happens again. Amazon link I like the tapered edge that these aluminum plates have. They allow for extra clearance between the plate and the visor. You install the drivers side with the opening facing the windshield, and the passenger side opening facing the pass. seat.
Jeep Wrangler JL jlur broken visor 1674325249693
Chupacabra
Greenville, SC
2021 JLU
Are those aluminum plates from Amazon something that one should consider installing *before* their visor breaks? I have a 2021 and no issues so far, but if this is a good preventative measure it might be worth installing them now?
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
That is what I’m doing this weekend.
NeilP
Neil
South Dakota
RETIRED!
I certainly would install them before they break . Apparently if you already have a broken visor, you can simply install the bracket and continue to use the broken visor
Opus
Midwest US
www.jlwranglerforums.com
I did mine as a preventative measure after seeing a few threads here about broken visors. I would recommend getting the aluminum holders rather than any plastic ones. The plastic ones can crack if you over-tighten them during installation.
Chupacabra
Greenville, SC
2021 JLU
Ordered them, will be here tomorrow. Might be too cold to mess with it now but I will slap them on at first opportunity :). Thanks everyone.
