Installed beadlocks, now steering wandering - fix?
joetimmons
joetimmons
Jacksonville FL
2022 JL
What trackbar are you running?
When you push the tires outboard, they have a longer moment arm and the larger forces they generate back-feed into the steering system from rolling resistance, bumps, road crown, wind side load, etc. IMO, the trackbar (and it's mounts) is one of the components that takes the brunt of these loads. If the bushings, mounts or the bar itself flexes and allows the axle to move laterally, the stationary draglink (assuming you hold the steering straight) pushes and pulls on the knuckle, which inputs a steering angle change.
XR stock at the moment , MC HD steering kit on order
While I like the HD steering kit and have it on my JL, and I think you will benefit from its strength when wheeling, it may not help your current wandering issue. IMO, you would benefit from a stiffer trackbar with harder bushings. BTW, the OEM tierod, draglink, and trackbar are all manufactured with staked on ends, which are more likely to work loose than a threaded end like the MC stuff.
joetimmons
joetimmons
Jacksonville FL
2022 JL
Yeah after I throw on the MC steering kit and game changer kit (+Front & Rear Durotrak™ Track Bars) + proper alignment of geometry etc I am hoping I am g2g.
I may throw on a PSC hydro steer too
I'm on 37s and not had reason for the PSC kit so far.
joetimmons
joetimmons
Jacksonville FL
2022 JL
Update: still wandering like crazy, & I am still curious about the technical reason vs the variables that I changed that have thrown the JLs steering way off,
Doing a side-by-side I changed 3 variables
1. Weight (+9lbs with new rims each)
2. Dimension (new rims are 1inch wider 17x9 vs x8)
3. The obvious one is going from a +12mm offset to -38mm, ~3.5bs @ 1.97" away from the frame for each tire.
Out of those 3 variables which one caused the wandering or is it the combo of all 3? I see a lot of suggestions on caster angle but keep in mind I still have bone stock XR Rubi and everything else so there isn't much I can do aside from lowering tire pressure to try to help - is there anything that can be done with the bone stock config to fix this or do I require additional $$$ and parts to have normal steering back?
Jeep Wrangler JL Installed beadlocks, now steering wandering - fix? Screenshot 2023-05-21 at 3.16.07 PM
hoag4147
Colleyville, TX
2022 JLUR XR
What is your tire pressure?
Roky
Roky
https://www.jlwranglerforums.com/fo...ow-steering-wandering-fix.113521/post-2359027
:headbang:
hoag4147
Colleyville, TX
2022 JLUR XR
Headbarcode
LI, New York
2019 JLUR Stingray 2.0 turbo
38psi is too high. What size tires? 32psi or under is where they should be, for a happy middle ground of good tire wear without being too mushy. The lower pressure will help lessen the wandering, but a higher caster angle is the real ticket.
hoag4147
Colleyville, TX
2022 JLUR XR
He has the 315s from the XR. What did you run your 35s at? I know that was FOREVER ago ?
joetimmons
joetimmons
Jacksonville FL
2022 JL
Just aired down to 32. thx!
