Steering wandering
americonium
Abe
NY
2018 JLUR Black
Engineering Technician
If you're constantly correcting the direction of your Jeep, and it feels like there's about 1 inch in the center that does absolutely nothing, then may I, as others have, suggest installing this. My Jeep has been telling me where it wants to go for the last 55,000 miles. I installed this with an addition to a 3.5 lift, and boy, did it make a difference. The steering is firmed up, I no longer have to constantly correct the direction, and I'm very happy with the results. Good luck.
vetygud
Michael
Nisswa, MN
2022 Jeep Willys 2 door Sarge
Retired LEO
If you are looking for the Mopar longer front LCAs, I found them at Quadratec for $44.43 each. Their part number is 56015-0324 and the Mopar number is 68322798AA. I had installed a 2" lift (actual 2.5", springs and shocks) and replaced the front LCAs. Caster is at 5.7 and 5.4. My 2022 Willys, a 2 door, had wandered from day one. I replaced the SS with an AEV/Bilstein SS and a Clayton Off Road relocation bracket. That stopped the wandering and got the SS out of harms way.
Jeep Wick
Wick
America
2022 High Tide XR
Mechanic
Thanks for your input.
Another vote for Mopar lift control arms... these made a big difference on my 2020, so much in fact that it drove better with the old steering box than the updated 2022 I have now. I bought another set to put on.
Coreyb516
Corey
New York
2020 jeep JLU
https://www.amazon.com/Synergy-Fron...a7-9432-5c55f11c708b&pd_rd_i=B08MB565FY&psc=1
I posted in the general group and I guess I messed up. Thread got hijacked.
First time Jeep owner. All stock 2019 JLU Sahara. Indiana does the chip and seal the roads are very un-even.
My jeep wants to wander, sometimes it's kind of scary. I asked about a aftermarket steering stabilizer, but think this more of my issue.
Tires are brand new, and not my choice.
Thoughts?
There is a service bulletin for the power steering gear and wandering I literally complained about this every single day until the dealership decided to change the power steering gear
Upnarms
AZ
2019 JLUR, 2003 TJ X
Before you dump a bunch of money into arms, ball joints, etc, i would do a through shaft stabilizer like the falcon (the one i run) or fox. Contrary to many of these responses they do make a huge difference in the wander. I agree a standard one is a waste. But the through shaft is tight. My steering stayed planted where i put it.
I upgraded other components, but the thru shaft stabilizer made the most immediate difference in feel, slop removal, and took away the pull, wander.
Long term, id consider tie rod and drag link upgrade, hd track bar.
Just check that your ball joints are tight but don't jump to replacing those cause you "think"they may be worn.
Tim_JLU
Tim_JLU
Tim
2019 JLU Sahara
This makes sense to me. My jeep is stable on a smooth road, I have no complaints. This leads me to think the parts are ok.
But on a crappy road, like one that has been chipped and sealed. It wants to follow the imperfections in the road.
I had to hit the brakes a few times I thought I was getting pulled into a ditch.
My F150 did it also, but not as bad.
