Willys41
- Larry
- Nov 2, 2021
- Pleasanton Ca.
- 2020 Jeep Willys
From what I have read water wetter can help and I use it in my jeep put in the case of the Wrangler It a rad. fan issue.I often see 240+ in the scorching Summers here in Las Vegas, especially when going uphill. I have been very tempted to use Water Wetter, but I'm one of those owners who religiously avoids gimmicky additives that don't work or can even cause damage.
I suspect this isn't the case for Water Wetter, but I would like to know how much you add to your engine coolant and about how much it reduces your engine temps. Seems like this could be a cheap/easy way to bring temps down, but I've been a little hesitant because cheap/easy never seems to work out well. Love to hear some testimonials from you and others who use this product regularly. Thanks in advance and appreciate your insight.
I had the same 235+ temps pulling hills and spent 6 months trying different things to lower the high temps.
RPM Extreme JL fan controller is the answer.
After the install the highest temp I have seen is 212 pulling a 8000 mountain pass.
Jon builds them for JKs AND JLs.
