zouch
- Sep 17, 2020
- Berkeley, CA
- XJ, JLUWD
first, read the instructions so you have some idea of what you're trying to do and how to do it.
i find taking measurements to not be particularly useful. since what i'm trying to do is adjust the speedometer to read accurately, i'll take a drive on the highway with a GPS program indicating speed and see if the J**p speedo is reading high or low, and adjust the tire size entry on the Tazer up or down until the speedo reads correctly. start with some value that's almost an inch smaller than what tire size you think you have (i.e.; 36.x for 37s). yes, it will likely take a few tries.
regearing costs vary depending on who does it and (to a lesser extent) what parts are used, but expect it to be $2-3K.
i would work with a speciality shop experienced with regearing J**ps rather than the dealer; it's not likely anyone at a dealer sets up gears often enough to be in good practice at it, and it seems to be as much art as science.
i don't know of any good reason to use the Tazer to program in invalid values for gearing. what's the point?
EDIT:
note: you should not have your phone plugged into the J**p while you are trying to get your speed check; at least some phones will pick up the speed off of the (inaccurate) speedo in the J**p..
EDIT:
yep its first on the list to do today tazer so I havenāt read the instructions yet cause Iāve only done the TPMS but what tire size do I enter or 37 do I do a chalk test or just enter diameter? and on another note what is the cost of regearing?
Is it better to do it at the dealer so that itās warranty and if I end up buying an extended warranty that should be covered as well?
Or should I do it at a well qualified shop?
here is another really dumb question but I just donāt know the answer to it
What would happen if you programmed with a taser that you have 488 gears when you really have 456 gears?
Itās only like a 7% difference with the computer. Just read that horsepower and torque down a little bit or something entirely unforeseen happen?
