Regeared finally
b1er
Alexander City, AL
'18 JL Rubicon, '18 JL Sport, 1980 El Camino, 1969 Olds 442
4.88's with 37's and I have 8th gear back. So much nicer to drive.
4 Wheel Parts in Pelham AL charged me 2100 out the door with a 3 year no questions warranty and a tire balance. Seemed fair enough to me...
b1er
b1er
Alexander City, AL
Waffled back and forth over 4.88 or 5.13... did the math, read about others experiences, and talked to the shop... I don't "offroad" much and like where you live, there aren't any rocks to crawl... so I decided to go with 4.88's... 5.13's would be fine and the difference between them is negligible so I opted for lower cruise rpm on the highway... on the 70 mile drive home, I went from an average of 15.4 to 16.7 mpg... you can't go wrong with either option in my opinion...
vtech243
Ian
Boston
Wrangler JL & BMW X3 M40i
Been lurking on multiple threads in this sub forum. @b1er — has your acceleration from a dead stop noticeably gotten worse? For highway purposes the biggest complaint I have is too low RPM at ~65 MPH and needing to constantly give the Jeep more gas to downshift. I used the Tazer to recalibrate and I actually have the problem that my auto tranny up shifts too easily. I’m constantly up-shifting and slowing down with the same pedal force. I do not see as much impact in city driving. Trying to weigh the benefits of dropping $$$ to re-gear. I’m in a Auto Rubi with 37 KO2.
b1er
b1er
Alexander City, AL
no, it got better after the gear swap... my rpm @ 65 mph, like yours was way too low... as soon as mine shifted to 8th, it'd start slowing down and I had to get it to downshift to 7th to regain speed... then it'd shift back to 8th and slow down again over and over... it wouldn't maintain speed in 8th...
After the swap, it cruises about 400 rpm higher, 65 @ 1900ish, 70 @ 2100ish and 75 @ 2300ish
Mine feels like it did stock... good acceleration, good power for passing, maintains speed well... I'm glad I finally did it...
vtech243
Ian
Boston
Helpful & thanks — which product / brand did you end up going with?
b1er
b1er
Alexander City, AL
Spicer gears and install kits... That's the only company with gear sets out now in quantity for the JL... parts were about a grand with 800 labor...
halffrozen
Drew
Goodyear, AZ
2018 Jeep Rubicon Unlimited
Do you mind sharing your parts list?
b1er
b1er
Alexander City, AL
Sure.
See below,
Dana Spicer 10051746 4.88 Front Ring and Pinion
Dana Spicer 10073110 4.88 Rear Ring and Pinion
Dana Spicer 10040478 Master Overhaul Kit Rear
Dana Spicer 10040469 Master Overhaul Kit Front
Redneck_Jedi
Currently Roaming
2019 Jeep Wrangler Sport S 2 Dr.
Congrats on the Re-gear! Just curious, was the re-gear done on your Sport or Rubicon? I will most likely re-gear once I go to larger tires.
b1er
b1er
Alexander City, AL
It was the Rubicon... my wife DD's the Sport on 35's and loves it.
