Finally test drive a 392
Overwatch
Los Angeles
2016 JKUR, Sarge Green 392
Just my opinion, I get that, but I love mine. I respect other's views and if it's not for you that's fine. However you came on here to tell others it's not that great which sounds more like sour grapes that you didn't buy it. It is plenty fast...scary fast for a Jeep. Comparing a 2.0 to a 392, that's just not going to work.
BigTalker
Peter
Maryland
2018 Jeep Sahara
I just got back from a dealership in PA and test drove a used (5k Mile) 392. I was planning on either ordering a custom 392 or getting this one, but wanted to test drive before I pulled the trigger. My experience was exactly like the OP's. I was just looking for confirmation to buy but that test drive has me second guessing it. All the videos and comments I've seen the thing should have blasted me into orbit, but pedal to the metal on the highway felt almost identical to my '18 Sahara V6. I'm so confused now... anyone have any suggestions why the one I test drove lagged or didn't seem any different?
Traveller128
Robert
Oasis Idaho
2022 Willys 2 Door 6 speed
Volvo Master Technician
You lose 3% of horsepower per 1,000', but I've never heard that translate into 0-60 impact.
Of course it does. You lose power at higher altitude, and acceleration slows as a results. In drag racing, there's altitude correction factors to correct for E.T. and trap speed so you can factor for correction at different tracks. As soon as you get away from a "standard day", then you gain or lose depending on air quality (temp and humidity, pressure altitude). 0-60 numbers are only accurate for the conditions they were run in originally, and don't reflect running in worse atmosphere. Weight of the vehicle is also a factor, 1/3 tank versus full tank runs are quicker.
HBDiesel
J
22 Wrangler 2018 Tundra 2018 4Runner 69 Chevelle
There’s a video of the 392 at 5000 feet it runs 6.8 or something like that to 0-60. light weight with high power if you want to go street car fast.
I don’t see any use for a “fast” Jeep. But to each there own.
Steph1
Steph
Quebec, Canada
Jeep JLU , Audi Q5
The XR makes a huge difference. My last jeep was a JKUR manual with 5.13's and 37's. The 392 is definitely MUCH more fun. Once you do all the fun mods (lift, gears, 37's, protection and winch) the 3.6 is a dog in comparison. As it was mentioned above, a ballerina. A large, athletic ballerina, much like a NFL defensive lineman. It throws heads back and makes heads turn. If you couldn't get it to 60 in under 5, 3 things may have happened......you didn't do it correct, the timer you were using was not used properly or you didn't have a footprint gas pedal.....because it is a HEMI!!!
I can totally relate. When I sold my 911 which I totally loved and was overprotective of, the feeling of relief far exceeded sorrow when I saw the new owner leave my house with it.
Bayrat
DA
NY and Fl
2023 Rubicon 392 - 2024 Gladiator Sport BAREBONES
This is the 392 I drove last week, it's a 2022 and used as a daily driver and in the mud and dirt back country. It does not have the XR package, yet it rode and handled much better than my 2019 JLU with the six banger. From a rolling start, this thing will suck the air out of your lungs.
Jeep Wrangler JL Finally test drive a 392 20220623_113949
rickinAZ
Rick
Phoenix
2026 MOAB 392
Just to be clear, I wasn't suggesting that power doesn't impact acceleration. I just hadn't heard of an actual rule-of-thumb for 0-60'. I've only heard 3%/1,000'.
I lived at 8,200' in the Colorado Rockies for most of my adult life. I felt the elevation impact every day.
Traveller128
Robert
Oasis Idaho
No rule of thumb, as there are so many vehicle specific things that will affect it greatly. Power to weight, gearing, all comes into play. A light car with good gearing might only lose a few tenths, while a, say, 5800 turbo brick will lose 1.5 .... :giggle:
BEACHED WHALE
SLC
JLR
The forum shares great insight and opinion (much better on the regular forum). In fact I was convinced by another member w/out ever test driving by way of the charts. The truth is a lot of people are buying $90,000 Jeeps w/out test driving. Im just hear to say that its not light and nimble like the jeeps we are all accustomed to. Not even close to the heavy diesel. It drives like a bad truck. The 2.0 came out just a few years ago after the JK. Being that the JK went through the "MOD renaissance" there was tons of insight & research done. Its a far superior engine then the old pentastar. In fact its an upgrade when you fill out trade-in value. So If I were to choose either the bronco raptor or 392 w/out driving, I would choose modern tech & go Raptor. The 2.0 turbo gives a similar feel to todays engines. The takeaway I hope here is to go out and test drive one before you put a deposit or wait for something u won't be in love with.
2nd 392
Ca
Grand Cherokee SRTs are just as heavy as a Wrangler 392.
My guess is the key variable holding back acceleration on a 392 are the 35-inch tires. It takes a tremendous amount of torque to start turning those tires.
Butt dyno tells me the GC SRT is likely a little quicker than my non XR, but it certainly wouldn’t lose it (until 99 mph) just wish the GC had a loud button. BTW, the GC has been a garage Queen since getting my 392, there is a reason! Much More Fun to drive!
3TV
Southwest USA
2022 JLUR 392, 2025 JLR
Even my TRX has been a garage queen since I got my 392 XR, except for one spirited run in the desert, which the TRX does very very well. I don't plan on 90+ mph runs in the desert with my 392, but for slower more technical terrain, daily driving, ease of parking, and just a great driving vehicle, the 392 is hard to beat as far as I'm concerned.
DaltonGang
Doesn't Play Well With Others
So, let me get this straight. You would choose the Bronco/Raptor over the Jeep 392, even if you hadn't driven them. If you couldn't figure it out, I'm now rolling my eyes at your comments, and logic.
Just out of curiosity, is MPG also a big factor in your off-road decisions?
