Finally flexed it out with a forklift
UncleArt
Arty
Western Washington
2022 Wrangler JLR 3.6l, 6MT, 4.88s
I finally flexed it out. It’s nothing extreme - but I think it’s pretty good for a daily driver.
2.5” Rock Krawler Adventure-X “No Limits” lift on 37s
Front 23” to bottom of fork
Rear 21.5” to bottom of fork
The rear was on its bump stop. I definitely need to trim the rear pinch seam.
I’m a little concerned about the tire touching the AAL liner bracket. Anyone have to deal with this?
*** UPDATE ***
I did confirm that the anti-sway bar reconnects when the engine is shut down. So these photos & measurements are with the sway bar connected. I flexed it out again with the engine running & got about 34” front & 32” rear. Super pleased with the results!!
See post 23 below…
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3757
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3761
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3764
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3766
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3758
Roky
Roky
Is your sway bar disconnected ?
UncleArt
UncleArt
Arty
Western Washington
Yes.
I have read that even though it’s disconnected, there could be some binding. Not sure if this is true. The RK links are pretty flexible though…
Roky
Roky
Yes.
If you have the no limits links, there’s no binding with them…. It just looks like something is keeping it from fully flexing…..
UncleArt
UncleArt
Arty
Western Washington
My rod end links are the 70° service free ones instead of the 95° rod ends. You think I should have gotten more flex? Hmmm. I’ll have to investigate… maybe I’ll reach out to Rock Krawler.
Roky
Roky
Yeah, the stuffed wheel should be more up in the fender…. It’s like there’s to much bump stop or something…. Those maintenance free bushings have plenty of misalignment….
In the pic where the forklift is lifting the rear tire the front passenger tire should be stuffing up in the fender……kinda like this..
Jeep Wrangler JL Finally flexed it out with a forklift IMG_9290
UncleArt
UncleArt
Arty
Western Washington
Ok thanks for this. I’m pretty sure I’ve seen posts where articultion was still being inhibited by rubicon’s disconnected sway bar. I need to search for this
Roky
Roky
I did a comparison a few years ago, there’s no difference between connected and disconnected using the no limits links…. Here’s pics
hooked……
Jeep Wrangler JL Finally flexed it out with a forklift IMG_7917
Unhooked…..
Jeep Wrangler JL Finally flexed it out with a forklift IMG_4949
UncleArt
UncleArt
Arty
Western Washington
hooked……
Unhooked…..
Ok this is good to know.
I’m now thinking about earlier today when I was picking that back wheel (my first time doing this). I’m wondering if I just stopped lifting too soon - the rear passenger wheel started to move so I stopped.
Roky
Roky
That’s possible…… also, if you shut off the engine the sway bar will reconnect… I’m not saying that’s what happened, it just has that look of a connected sway bar…do you have pic of your bump stops and which shocks did you pair with your lift ?
UncleArt
UncleArt
Arty
Western Washington
I did shut off the engine! I didn’t know it would reconnect. 🤦🏻
Ok - I need to redo this.
UncleArt
UncleArt
Arty
Western Washington
Jeep Wrangler JL Finally flexed it out with a forklift IMG_3767
this is the only bump stop pic I took with the driver front lifted. I’ve got Rock Krawler’s shocks. The fronts never touched the bumps - which I thought was strange at the time.
Roky
Roky
Yeah, that looks like normal amount of bumps for that kit and the RRD shocks, my guess is that it reconnected on you….
