Engine air filter - how often to replace?
Wbino
NJ
How often is it replaced?
I just had an oil change and had the dealer replace it at 16k miles.
NJJeep Guy
New Hampshire
2020 Hella Yella JLU
You replace when it gets dirty enough. Greatly depends on the local environment. I'm sure I can wait far longer here in the Northeast than someone rolling around and wheeling in Arizona every day.
Valpo Jeep
Doug
Valparaiso IN
Maintenance schedule in the owners manual recommends a 30K interval. For my area my filters have always looked good at 30K on any car I have ever owned.
CarbonSteel
Air filters (until the point it clogs or tears) will become more efficient as they are in use. Unless being operated in an extremely dusty environment, most air filters can go 50K miles without any issues.
16K is too soon to change it unless in an extreme environment.
An air filter restriction gauge is the best way to monitor air filter health:
Jeep Wrangler JL Engine air filter - how often to replace? 200135f_480x292
zrickety
Technician
Anecdotally, our Honda Pilot started misfiring at 60k on the original air filter. It actually went into limp mode because of this.
As others said, it will depend on your use but 16k is early.
Dgr401
Dennis
Rhode Island
2020 Wrangler JL Sport S - Granite Crystal
I checked mine at the 30k mileage recommendation and was surprised as to how clean it was, not perfect but in decent shape. I decided to wait until the pollen season has finished and will check it again.
Heimkehr
Pennsylvania
2021 JLU 2.0T
I replaced the original OEM filter at 30K, per the prescribed interval noted in the Owner's Manual. The filter has obvious service life remaining, so I put it aside as an emergency spare.
Jeep Wrangler JL Engine air filter - how often to replace? IMG_20230414_092441
Antonio
Antonio
NJ
2022 JLU Rubicon diesel
If you off-road offer, then I would recommend changing sooner, I usually clean mine at every other oil change, I just blow it out with my air compressor and clean the housing if needed, I’ve seen some at 30 K and they still look good
bbroich
Bend, Oregon
2022 JL Rubicon
This question of when to change the air filter reminded me of one time with my old Ford Explorer.
I was a volunteer fireman and had a tap out for a call. I jumped into my Explorer and started out but whenever I got above about 10 MPH it would die. I knew I wouldn't get to the station in time, so I limped into the Ford dealer. I thought it must be a problem with the fuel injector. They called me back in within an hour, and on the guys desk was a quart jar filled with yellow jacket carcasses'. They blocked enough air to starve the engine whenever much above idle. Strange how they found there way into the housing in enough numbers to cause the problem.
Heimkehr
Pennsylvania
2021 JLU 2.0T
...a quart jar filled with yellow jacket carcasses'. They blocked enough air to starve the engine whenever much above idle.
A few years ago, I got stung while standing next to my shed. A quick inspection revealed no nests in the eaves, etc., so where were they coming from?
I eventually determined that there was a large, pancake-shaped yellowjacket nest under one of the decorative shutters. Unscrewing the shutter, spraying the nest and getting away quickly required practiced, fast movement, but I got it done.
Every year, it seems that it's something different. Thus far, carpenter bees appear to be this year's bother. ?
Wbino
Wbino
NJ
For $31. dollars installed I considered it a no brainer.
I spend more for gas.
bbroich
Bend, Oregon
2022 JL Rubicon
They are crafty little devils. I found an underground nest of them once, right below my kitchen window. I thought I'd drown them out, so got a water hose and trained it on the opening. Immediately a swarm flew out and attached me repeatedly while I beat a hasty retreat. I waited till night when they were unaware and bug sprayed them while they slept. Revenge is sweet.
Tncdrew
Tom
East Tennessee
2022 JL Willys, 3.6L - 8spd
I have to admit, after reading your comment, I was really scratching my head... huh? What?? ?
Then I found this Donaldson article that explained it. Makes sense!
I had '96, and '99 Chevy & GMC's that had those Donaldson restriction monitors upstream of the air filter.
https://www.donaldson.com/en-us/engine/filters/technical-articles/servicing-by-restriction/
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
Mileage has pretty much nothing to do with the need to replace your air filter. On my vehicles, they get checked at every oil change and replaced as needed. Probably every 3 or 4 years.
QwikKotaTx
Houston, TX
2015 Hemi Ram, 2002 Porsche 911 Turbo
I definitely wouldn't pay to have it installed but for the price of an air filter on Rock Auto I replace mine every 15k miles, honestly. I buy 5 or 6 at a time to save money on shipping.
