How often to change transmision fluid?
Jeep Junkie
Muhammad
Seattle, WA
2024 JL Wrangler Willys
This Pacifica made it to 500k miles but blew the transmision in a little over 100k miles. The guy blames that on not changing fluid early enough, otherwise ZF 8 spd would have made it to 500k miles too. He says 30-40k miles is the best interval. What do guys think?
kah.mun.rah
Merenkahre Jr.
Duat
My gasket is leaking so it looks like I will be changing mine at 70K. Otherwise I do it at 100K miles. The T-case I do at every 30K (recommended every 60K), and axle fluid every 25K (recommended every 40K).
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Why is it leaking?
kah.mun.rah
Merenkahre Jr.
Duat
Why is it leaking?
I'll find out once I change the gasket. My guess is that it has a loose bolt, a stripped bolt, or a misaligned gasket. I don't think I have hit the pan on anything but that is a possibility too. FYI, I just looked it up and it looks like they recommend changing the trans fluid every 60K miles so I guess I am overdue.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
I see. Hopefully it is just that and your ZF keeps rocking.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
Parts on Mopar website.
https://store.mopar.com/oem-parts/m...ter-68417054ab?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
https://store.mopar.com/oem-parts/mopar-automatic-transmission-fluid-68218925ab
https://store.mopar.com/oem-parts/mopar-oil-pan-gasket-68522534aa?c=bD0xJm49U2VhcmNoIFJlc3VsdHM=
kah.mun.rah
Merenkahre Jr.
Duat
It's just a little seepage at the seal, not even dripping. Most people wouldn't even notice and those that do, most wouldn't bother, but I am particular about those things.
Heimkehr
Pennsylvania
2021 JLU 2.0T
@Jeep Junkie
The ZF docs that I have in the Jeep's binder mention performing a fluid & filter change approx. every 60K miles. That's the interval that I have used and will continue to use.
I've done the job myself because my dealer refused the work, leaning heavily on the [fictitious, IMO] "Lifetime fill" language evident in the Owner's Manual.
When the time comes due, I'll replace the fluid & filter at least twice, with 1K miles in between. The system capacity is 9 quarts, but only 5.5 quarts, on average, will drain out when following the prescribed service procedure. Thus, performing at least two fluid & filter replacements in close succession (3 is best) maximizes the removal of the old fluid. Something to keep in mind.
X35
PA
2025 Wrangler Willys XR
I’m going to go with an every 25K mile trans filter/fluid change schedule with mine. My theory is that the 25K schedule will allow for fresh fluid without ever having fluid left in the trans that was stressed to the max mileage. This works for my OCD, YMMV 🤷🏻‍♂️👊🏼🍻
JeepTough
a
a
My 2023 2.0 Sport transmission fluid was black and burnt at 30k. No issues before and no issues after the service. 3k since service.
I drove the Jeep on and off road for the first three years, which was 30k.
Before the service I cooked it real good over the summer in Sand Hollow running my new 4.56 XR axles on true 35 inch tires.
I'm thinking I got lucky and I'm going to be servicing more frequently.
Just for fun, I've included my transmission service notes below.
For entertainment purposes only, do not use these notes for your own transmission service:
TRANSMISSION SERVICE - 850RE 8-speed automatic transmission
DRAIN
- chock tires, level the jeep
- remove fill plug, make sure you can fill it before emptying it.
- remove pan, drain fluid, remove all but the four corner bolts, then loosen all four but loosen the rear bolts more to drain.
- clean pan, magnets, and replace filter, don't over tighten filter bolts so filter neck can fit into valve body.
- install pan, 98 ft lbs or hand tighten
FILL
- FILL fluid until drains out fill hole. about 4 qts
- start jeep cold and fill while running, about 1.5 qts, at no more than 75 degrees
- Pump fluid until it starts to drip, wait, then pump more, repeat.
- FILL fluid until it won’t take anymore without spilling out, you want about 5.5 qt total.
- test drive, go through all gears
- cool to 86 degrees
- level jeep
- start jeep, idle, in park
- FILL or DRAIN fluid until level with bottom of fill hole.
