Lhewi207
I needed to replace the CAN-BUS. There was a short in the board. Once I replaced it, I haven’t had an issue since 2021 when it all started.Was this the fix for this issue in video below?
If it’s the CAN-BUS, while Jeep is on Run, wiggle the connections slightly. If there’s a short you should basically recreate every issue your Jeep threw at you. Just the slightest bump threw my Jeep out of wack. Power steering, gauges, wipers, etc.
Tip: if you decide to pull any wires from the CAN, just take pictures so you don’t get stuck wondering what wire goes to what.
