Lhewi207
I’m new to this Forum I’m going to try to be as detailed as possible, but anyways I have a 2018 Jeep JL Sport, manual transmission 40,000mi, just out of warranty. A few weeks ago I started my Jeep, all of my dash light came on: ABS, service 4WD, service Stability control, Brake, Start Stop, and airbag light. All gauges not working. I hooked my reader on the Jeep and had several codes pop up all relating to ABS.
15 minutes of driving, my power steering would stop working. I got the Jeep to where I needed to go and attempted to stop and restart the vehicle but failed to even shut the engine off. I stalled the engine but still couldn’t get the rest of the vehicle to shut off completely.Just before I unplugged the battery I tried shutting the Jeep off and it worked. So about a half hour before I could even shut it off. I started the Jeep and all the lights that were on were off except the Check Engine. Now this same incident would happen at random times. It would be okay one day and chaos the next. Certain lights would pop up like check engine and stop/start. Once I see all my lights come on I’ll know that my power steering will turn off at any time and does.
(Recently: when power steering shuts off. It would now come on and off at random times. I’m in a situation where I don’t have power steering going around a sharp corner then all of a sudden my power steering kicks back on. Other times It would be driving normal then for a split second no power steering and on again causing me to jerk the steering wheel while driving. Then my dash will shut completely down and basically resets itself and warning lights are off, and Jeep is back to normal until the next incident occurs)
I got a hold of the the only dealership in town which doesn’t really have a great reputation. I had them do my second recall relating to my clutch (software update) and to check on my main issue. I got a call back the next day stating that the software update was done and they placed their Reader on it and had 87 codes. They cleared codes and had a technician drive it with no issues and sent it back my way. Service department was closed when I was able to get the Jeep. As soon as I started the vehicle all my lights were on. Sent it back to the dealer and it sat for a week and a half before someone looked at it. They called me and basically said they don’t know what the issue is and I would have 2 options and the 2 options are not guaranteed to work. One being to have a technician to tear down everything and inspect wiring (quoted 7 plus hours labor) or replace entire wiring harness. So I took the Jeep back because I’m not going to gamble over a grand on guess.
just wondering if anyone has had this issue or similar experience and what the causes were? Or any ideas. I’m currently taking my ESS battery out to test it and inspect it.
Should also mention that I’ve had some electronic issues ever since I got the Jeep new and never got resolved because dealership could not recreate it. May or may not be related to issues I am having now I don’t know. But seen some forums about it but little answers. My radio would go haywire and make a loud pop and completely shut off and reset erasing uconect data and resets clock.
