Drag Link, ESC, and Check Engine - Help!
word302
Oregon
JLU
Unfortunately there's no way that will get covered under warranty.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
don’t think I could argue that it was defective?? Ha ha I think if it has to get replaced the question will be to replace it with the same axle and truss it up or buy a Dana 60 equivalent since it may end up those eventually.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Does everyone think that a dealership will fight the warranty on this? Any recommendations if it comes down to it?
my understanding is that they would have to prove that a 3.5” lift and 37” tires caused the axle housing to bend, if it is indeed bent.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Also, pretty sure the tie rod end on the drivers side is bent. Passenger vs driver side below.
Jeep Wrangler JL Drag Link, ESC, and Check Engine - Help! F56E42D9-7B76-4A1F-9769-BC78D83A7523
Jeep Wrangler JL Drag Link, ESC, and Check Engine - Help! 94045283-B668-49A4-AFD3-BBEBF1B55105
Spank
If you had your OEM parts still bolted to the axle, there's a slim chance that might work, but there's no way they'll cover that.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Maybe an insurance claim then? Technically it was a hidden hole on a town road.
word302
Oregon
JLU
They don’t have to prove anything. A bent axle housing is not normal wear and tear. You’re SOL man.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Spank
You'd probably have better luck going that route, but I still wouldn't cross my fingers.
19 JLUR Bright Whit3
Baba Yaga
NJ
www.youtube.com
Retired LEO
Just speaking from my POV. I have never had the dealership cover a thing under warranty in the past 3 years. Once they (the ones here) make a note in their computer the vehicle has been "modified" or "damage was caused from abuse", NOT! I was done. Yes, there are mod friendly dealerships out there. They will just note the customer issue and do the repairs and then FCA will reimburse them because all FCA knows is it was a stock vehicle with a damaged part. IMHO, dealerships do not want to take the risk of eating the bill and not getting reimbursed if FCA rejects their claim.
Roky
Roky
I’m late here, just catching up….. my .02, figure out what exactly is wrong first. It may be worth it to fix it yourself then claim it on insurance. Rates will definitely go up. Also I wouldn’t even try the dealership, will be just a waste of time IMO…….
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Any experience with that?
Not specifically a bent axle, but I do know comprehensive will cover broken wheels and tires from potholes. I’d assume they’d cover additional mechanical damage.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
Bad news and good news from the shop.
The axle housing did bend just inside of the C. They could bend it back enough to drive on, but it would always be week. Good news is no other components were damaged on the axle and only the drag link end on the passenger side was bent.
Good news here is that I am going the insurance claim route. Replacement front axle from Mopar is $5600 plus labor to install, so I am hoping the shop writes a quote to the adjuster for $6500+. I am going to take that $6500 and buy a tricked out Dynatrak ProRock 44 with all the bells and whistles; upgraded ball joints, RCV shafts, etc. which will run about $6,600, then pay my shop to swap it in. I debated going to a UD60, but then I have to buy new rims and I can’t afford to put a UD60 on the rear right now. I don’t plan to ever run more than 37” or 38” tires.
I am going to part out my Dana 44 XR Rubicon axle once it comes off. Sell the locker, gears, and axle shafts. Would sell the axle housing assembly locally too if someone wants to mess with it.
GATORB8
CLT NC
I was actually going to recommend considering an aftermarket axle if you went the insurance route. Hope everything works out.
May want to check lead times on the aftermarket axles.
FreedomFur
FreedomFur
Elliot
Concord, NH
2021 JLU Willys
I wanted to go UD60 but that bolt pattern is a pain. Got the shop checking with Dynatrak but they thought about 2 weeks.
