plex
- Oct 25, 2018
- Cincinnati, OH
- 2018 JLUR
- Occupation
- Weekend keyboard mechanic and beer drinker
- Vehicle Showcase
- 1
This indeed is very helpful. Here are my pictures before/after (actually driver and passenger) but you get it.It's a really old thread, but I thought I'd mention a really easy solution to get the door harnesses out of the way. Unplug the door harness from its connector like you would when taking off the door. On the driver's side, rotate the plug 360 degrees counterclockwise, then plug it back in. On the passenger side, do the same with the plug in the clockwise direction. Now when you close the doors, the torsional tension will coil the harness upward as it bows.
The first one (passenger) is twisted upward and out of the way, while the second one (driver) is the usually pointy towards driver. I can also confirm this twisting method is completely harmless to the cables and door limit strap, and does not change how door open/close functions at all.
