Door limiting strap annoying
plex
Cincinnati, OH
It's a really old thread, but I thought I'd mention a really easy solution to get the door harnesses out of the way. Unplug the door harness from its connector like you would when taking off the door. On the driver's side, rotate the plug 360 degrees counterclockwise, then plug it back in. On the passenger side, do the same with the plug in the clockwise direction. Now when you close the doors, the torsional tension will coil the harness upward as it bows.
This indeed is very helpful. Here are my pictures before/after (actually driver and passenger) but you get it.
The first one (passenger) is twisted upward and out of the way, while the second one (driver) is the usually pointy towards driver. I can also confirm this twisting method is completely harmless to the cables and door limit strap, and does not change how door open/close functions at all.
Jeep Wrangler JL Door limiting strap annoying 20190507_085703
Jeep Wrangler JL Door limiting strap annoying 20190507_161943
Sippican
Home
Jeep
Ya, I noticed it right away. Been looking at it for months now, hoping a solution will jump out at me. Im going to try turning the plug 360 and see what happens.
plex
Cincinnati, OH
It works very well, before the twist it actually shaved my left leg like a hipster...now the space is free up, I can actually use my dead pedal.
melendez69
Marc
Waxhaw NC
...huh?
So....I can stop using Nair? ;)
Billyraff
Illinois/Michigan
2019 Wrangler Sahara 3.6
Quality Specialist
Enjoy the strap, my new ram 1500 door slammed open and hype-extended with 60 MPH winds last month when I opened it. 2 weeks in the body shop, new paint, hinges, and plenty of $ later..
Sippican
Home
Jeep
Yep! Works great! Turned the plug 360 degrees, and now the strap stays close to the door. No more rubbing my leg! Thanks the the 'no cost' modification!
3illy
New Jersey
2019 JLUS Granite Crystal Metalic, 2013 Harley Davidson FXDF
I tried rotating counterclockwise which didn't really work. Then I tried rotating clockwise and it worked great! Thank you for taking the time to answer my question. I should point out that when I rotated the plug, I did it while holding the plug so that the female sockets were facing me which is probably not the intended start from orientation you were expecting. For others reading this thread, suffice it to say, if one way doesn't work - the other way likely will.
My third Jeep mod. 1 was a don't follow me sticker, 2 was a cargo liner. This one cost me nothing and is the best yet!
wolfdog
George
Southern Massachusetts
2006 Yamaha FJR1300, 2021 JTO, 2018 JLU Sahara
Maritime Artisan, Mayflower II
Hmmm, 2 JKU's, many CJ's, never noticed?? JLU is 27Jeeps later, no sense, no feeling I guess?? Now that I know, I wonder?
Melendez69, you can keep the Jeep but don't give up the Nair yet! lol
Go Jeep!!!
brazos
2018 JLU Sport, Giant singlespeed mountain bike, Hobie Revolution kayak
Dog Feeder
Noticed it once or twice. Ignored it since. All good.
wolfdog
George
Yup! No sense, no feeling!! Knew I should not have commented or read this post!!
Just went out and tried, guess I won't need any of Melendez69's Nair either, damn I would read this! lol not so much!
Go Jeep!!!
WhatExit?
The 48th State
2020 JT Rubicon Launch Edition | 2021 F350 6.7L
Just found this thread - I'll give it a try. I do wonder if/how twisting the wire will put a crimp in it when the door is opened wide. Any concerns about this?
Roky
Roky
No issues... I’ve had mine twisted for almost a year now. I just turned it a half a turn, unhook it turn strap over and re hook it. Works great, keeps strap up against the door. I’m in shorts 99 percent of the time so this irritated the crap out of me.....:)
Jeep Wrangler JL Door limiting strap annoying B7E35A1A-FD83-4250-B00A-20109AA7598B
Jeep Wrangler JL Door limiting strap annoying DBEC56FD-C100-4EAC-B9C3-9007606FEEAB
Jeep Wrangler JL Door limiting strap annoying 42B7B321-D60C-4DFD-8B88-FC3C39933966
wv18jl
WV
2018 JL
CarbonSteel
It has bugged me from day one, but have been living with it. I will try the twist trick...
