Differential Oil
TheDirtyDangla
Central PA
2021 JLUR 3.6 E-Torque
Putting some Motobilt's on and just want to make sure I have the right product here. Sport axles, not limited slip in the rear.
Genuine Chrysler Fluid 5136035AA Synthetic Axle Lubricant SAE 75w-85
Redneck_Jedi
Currently Roaming
2019 Jeep Wrangler Sport S 2 Dr.
Per my 2019 Owners Manual, It looks like you need 75w-140...
Jeep Wrangler JL Differential Oil delet
Jeep Wrangler JL Differential Oil delete2
No idea why the Limited Slip still calls for 75w-85 though.
TheDirtyDangla
TheDirtyDangla
Central PA
Interseting, don't quite know how to clip like that but I copy and pasted here from my manual
Axle Differential (Front) We recommend you use Mopar Gear & Axle Lubricant (SAE 75W85)(API GL-5) Axle Differential (Rear) We recommend you use Mopar Gear & Axle Lubricant (SAE 75W85)(API GL-5). Models equipped with Trac-Lok Limited Slip Differential require a friction modifier additive
vavaroutsos
Pete
Scotts Valley, CA
2015 Sprinter Crew Van 2500 High Roof 144" WB OM651 Brilliant Silver, 2019 JLR 3.6L 6SPD Granite Crystal
The limited slip is on the M220, not M200 axle.
Redneck_Jedi
Currently Roaming
Redneck_Jedi
Currently Roaming
That's odd; I wonder why they made the change to 75w140 in the M200 Axle for 2019, and left the M220 at 75w85.
JDLouisville
Louisville KY
‘23 Jeep Wrangler Rubicon 392 XR
186 FBI (Model 30) - Front Axle
MOPAR Gear & Axle Lubricant (SAE 80W-90) (API GL-5)
1.82 Pints/0.86 Liters
210 FBI (Model 44) - Front Axle
2.18 Pints/1.03 Liters
200 RBI (Model 44) - Rear Axle
MOPAR Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent.
For trailer towing, use MOPAR Synthetic Gear & Axle Lubricant (SAE 75W-140).
Models equipped with Trac-Lok require an additive.
2.43 Pints/1.15 Liters
220 RBI (Model 44) Rear Axle – EDL
3.06 Pints/1.45 Liters
220 RBI (Model 44) Rear Axle – T/L
3.02 Pints/1.43 Liters
Redneck_Jedi
Currently Roaming
Thanks. It looks like Jeep needs to update both the 2018 and 2019 owners manual with more detail.
WXman
Central Kentucky
Yep, especially since it lists the D35 as a D44 there. An erroneous bit of info like that makes you question the accuracy of the entire thing.
Therby
Taylor
Ontario, Canada
2018 JL sport 2dr
Still unsure about this.
Most stores carry 80-90 gl5 spec like valvoline, non synthetic for a good price
Would this be appropriate to use in the diffs with the friction modifier from mopar?
I like to change the gear oil twice a year to avoid contamination from water/mud etc.
Jeep Wrangler JL Differential Oil 262C3DF8-841E-408A-ABAD-87B005553E20
Jeep Wrangler JL Differential Oil 41F4F611-63F5-441E-87A4-EF4C68BEAA7A
FitBliss
Gabriel
MN
2019 Jeep Wrangler Limited Rubicon
So no additives are required for the Rear differential on the Rubicon? Only the Sahara or Sport/s that are setup for the LSD? I ask because I just got a kit from Northridge that came with 75w-140 and I planned on using it on the front diff as well? when I add my new Diff plates, could I get away with this? :fingerscrossed:
c2m2h3
US
2012 JKU Wrangler Sahara
I posted this in another thread....This thread may be able to answer it better...
Can someone please explain the differences with the Rubicon Axles ? If I order a 2020 JLUR with the 4.10 gears (D44 Front and Rear).... and the Trailering Package, which axles am I getting ? If there are any other options that would affect any variables, please ask.....
Do I get the ......
210 FBI ?
200 RBI
220 RBI EDL
220 RBI T/L ?
Sorry if this is pretty straight forward, but I figured I'd ask......
Thanks !
Mugzzzee
Hal (aka Mugs)
Bayfield, Colorado
2018 Jeep Wrangler JLUR, 2016 Jeep Grand Cherokee Overland
Retired since 2004
My 2018 Wrangler JLUR has tru-lok. The front and rear axles are the Dana 44 M210 front, Dana 44 M220. The 2018 manual makes no mention of using SAE 75W-140 relative to towing. Would it be wise to use the SAE 75W-140 in my rear differential as I will likely tow a small trailer with firewood? Or should I stick to the manual and use SAE 75-85?
