Differential Oil
DanW
Indiana
My 2018 Wrangler JLUR has tru-lok. The front and rear axles are the Dana 44 M210 front, Dana 44 M220. The 2018 manual makes no mention of using SAE 75W-140 relative to towing. Would it be wise to use the SAE 75W-140 in my rear differential as I will likely tow a small trailer with firewood? Or should I stick to the manual and use SAE 75-85?
You can't go wrong putting 75w140 synthetic gear lube in the rear, even if you don't tow. Still, you'd probably be fine with 75w90, again, full synthetic. I've run both in mine but settled on 75w140 in the rear and 75w90 in the front, all full synthetic, since I tow a boat and utility trailer occasionally. My JK Rubi has had 75w140 its entire life and the gears are in great shape after nearly 140k miles.
c2m2h3
US
2012 JKU Wrangler Sahara
Question:
With a New JLUR, If I went with AMSOIL Full Synthetic 75w140 in Front AND Rear, would that pose any issues ? I also plan on doing some towing....not a lot, but some.....
CarbonSteel
Question:
No issues at all other than a potential slight MPG hit, but who buys a JLUR to use as an econobox? I have Amsoil 75W-140 in the rear and 75W-110 in the front.
c2m2h3
US
Why the 75W-110 in the front ?
CarbonSteel
75W-110 is the upper viscosity that 75W-90 used to be before the SAE J306 tables were updated some time back. I like having a bit more viscosity protection.
c2m2h3
US
Got it. Thanks for the replies !
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
I went with Amsoil 75W90 in front and 75W140 in rear. 2oz. of Mopar friction modifier. So far, so good. No change in mileage.
c2m2h3
US
Are you running full synthetic ? if so, why the modifier ?
jmcdtucson
Jerel
Tucson, AZ
2018 JLU Sport S
Sport with LSD requires a friction modifier regardless of conventional or synthetic.
c2m2h3
US
So a Rubi with Full Synthetic wouldn't require the modifier ?
c2m2h3
US
Thanks ! Just checking .....
jeepdabest
Bobby
Arizona
2019 JL Sahara
Will I need to remove air dam to get to front diff?
damyers8
Duane
Ohio
2019 Punk'n JLUR
I had no issue changing out my differential fluid while the Jeep was on the ground. The front was a bit tight, but still was an easy job.
jeepdabest
Bobby
Arizona
2019 JL Sahara
Was there a particular side you approached from?
