failsafe306
Tulsa
2022 JLUR 2.0
They ride great…. They were just a couple inches shorter full droop… also I wanted (which I use a lot) adjustability…. They’re a little softer than the foxes, but not too soft…. Mine don’t have the IFP either so, the ones out now are even better than the ones I have…..When I have to use them I’m thinking about using the MC shock brackets that raise the shock 1.5” that would make my articulation close to the same….
Oh so the new new ones are mono now? Cool!
Roky
Roky
Roky
I’m pretty sure, I know if I wanted to I could send these in and have them converted…@word302 did that…..
Roky
Roky
Roky
Got a free couple hours Sunday morning so went wheeled a little….We’ve had a lot of rain lately, so our 2-3 rated trails turn into 8-9s because it’s like wheeling on a bar of soap…lockers, 4lo, doesn’t matter, some spots are winch only if you want to, but there’s usually a go around… I always clean and do a post wheeling inspection, grease and WD 40 if necessary….When I pulled center caps to grease RCVs, I found this…:facepalm: .. I have no idea how long it’s been loose but I never felt or heard anything from it….
Jeep Wrangler JL Crystal Rubi build… IMG_0803
I know the unit bearing is pressed together pretty good, but I still figured it would have separated… That is until I watched this..Those are some pretty hard smacks with the sledgehammer…… I see how it’s possible now to not have it come apart, but I know I was on borrowed time…… I put loctite on them and torqued them to 150 ft lbs. I’m probably going to stake the nut as well, but I’m looking for other options to lock it down….
oceanblue2019
Northern Arizona
2019 JLUR 2.0L Auto
Consultant
The 3 bolts that hold the unit bearing to the knuckle are pretty tough. They are $50 each from Mopar so not your typical bolt. Plus the unit bearing goes into the steering knuckle bore so no shear loading on the bolts - just keeps it in the bore.
But you basically were just were driving around with 3 12mm wheel studs ;)
Roky
Roky
Roky
I’ve put about 500 miles on her, combination of on and off road. Axle nut still at 150 ft lbs….. healthy dose of Orange loctite and 150 lbs torque seems to be doing the trick…. I have a couple other options if it loosens up again, but for now I’m gonna roll with it…….✌
Jeep Wrangler JL Crystal Rubi build… IMG_0484
Roky
Roky
Roky
Took a trail less traveled this weekend, picked up these guys….
Jeep Wrangler JL Crystal Rubi build… IMG_0958
Didn’t even know it till I got home…🤣 We don’t kill what we don’t eat around here 🙄 ( not sure anything less than a bullet would do it anyway..🤣)….so back to the woods I go to return them…...That’s ok, any excuse to get off the grid , I’m down…
This one was already taking up residence, it was hard at it, building the web…..😂
Jeep Wrangler JL Crystal Rubi build… IMG_0955
Jeep Wrangler JL Crystal Rubi build… IMG_0956
shagles
Skylar
2020 JLU Sahara
adult toy engineer
Didn’t even know it till I got home…🤣 We don’t kill what we don’t eat around here 🙄 ( not sure anything less than a bullet would do it anyway..🤣)….so back to the woods I go…..That’s ok, any excuse to get off the grid , I’m down…
Jeep Wrangler JL Crystal Rubi build… {filename}
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
Nobody rides for free!
Omen
Wisconsin
2022 JL Willys 2.0
IT Manager
@Roky
Will Colby play with or eat those? My cats devour anything with more than 4 legs.
Are they dangerous?
Creepy as shit, they are!
Roky
Roky
Roky
@Roky
Are they dangerous?
No she’s pretty lazy these days, lol.. she’s 12 now and unless it crawls over her nose, she just sits there and barks at it…🤣…….they’re called a Golden Orb Weaver, us locals call them banana spiders…. Relatively harmless …. It’s bite is painful but not dangerous to humans….definitely prehistoric looking though 🤣
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
I didn't take you as one of those guys who decorates his Jeep for Halloween!
jeepingib
Dusty
College Station, TX
18' JLUR Punk'n
BBQ prophet
Well, it wasn’t on purpose I assure you….🤣
You'll be a hit at the local trunk or treat, I'm certain.
