Changing Tire on the Trail???
J0E
J0e
Hawaii, MT, SLC, NYC
bt39.com
2021 JLR, 05 LJR on 43s
That won't lift enough to change a 38 on my JLR or a 43 on my LJR. You don't need 10 tons, the 4 ton is overkill.
EDIT
The BAOSHISHAN 12 Ton High Lift Bottle Jack 9.25" to 23.23" would provide enough lift but not require driving over a rock.
Flip
Johnny
Virginia
2023 Jeep Wrangler Sport
Retired Power Plant Engineer
EDIT
I have a 21" jack but as someone pointed out I might need a smaller jack to get under the axle. I have a scissor jack too but I've never been a fan. Carrying an extra jack isn't a bad idea, I get a lot of flat tires.
  • Like
Reactions: J0E
J0E
J0e
bt39.com
Not exactly.
When you have a flat, the axle is about 6" off the ground. You need a jack that will fit under that height or you have to dig out a hole for a taller jack to fit, or drive the flat tire up on a rock (further exposing the tire to damage). Once you get a jack under the axle of a flat tire, you have to jack it whatever height your flattened sidewall expands to with air. This is where having a low scissor jack works well and guys that bought a bottle jack using measurements under their axle when their tire was inflated, are going to be surprised when they get a flat.
I carry spacers. I've seen at least 10 youtubes on jacks and they test the jack with the tire full of air. They get surprised when they get a flat on the trail.
Flip
Johnny
Virginia
All this talk about jacks made me realize they have a lot of different mounts for farm jacks but what about a mount for a heavy duty (beefy) hydraulic jack? Some of these can weight quite a bit. A bumper mounting option would be nice, safer out of the way, I'd be interested in one.
J0E
J0e
bt39.com
Not to change the subject but does anyone carry a battery powered impact to change out a flat tire? If so which brand, do you have that actually has enough torque to remove the lug nuts?
This Ryobi is a torque monster. Use it to change tires, run the scissor jack. Carry 4 batteries, 4 tiny compressors to air up, 12" chain saw, 3 lights, angle grinder, 3/8 right angle driver, recip saw, and more.
I like that angle grinder idea. Last flat I had, the steel belt was frayed and sticking thru. A disk grinder and some patches fixed it up at a tire shop. But, I'd like that capability for the trail in a real pinch.
txj2go
DFW
Interesting! I had not thought of that scenario at all, clever. This is a time where a hi-lift would likely be necessary. A bottle jack likely would struggle in this scenario.
My point was that there are lots of different scenarios and most of them will not be easy. It might be a struggle with any jack. Be prepared to work at it.
GATORB8
CLT NC
21 JLURe, 06 LJ, 25 HDZR2
Milwaukee M12 fuel 1/2”. Tiny and does it’s job. Plus you can charge M12 batteries via USB.
J0E
J0e
bt39.com
Carry thin kerf metal blade for cutting metal and think grinding wheel for smoothing the sidewall as shown on utube.
Run 295/70R17 E rated KO2's on my TJR after blowing too many sidewalls on K02 C rated. The pat's guys here tear a sidewall every time we crawl one river bed. Half the price of Nitto's and 1% the sidewall strength. My 38x13.5R17 Nittos are only D rated, but the sidewall is so think I needed to add a spacer to my beadlocks.
Everyone should carry starting fluid to reseat a bead, unless you have dual beadlocks. Practice that at home, just like you should practice tire change with trail gear at home with a flat tire, in your yard, not the driveway.
PatriotX
Midwest/Great Lakes
2022 4xe
I carry the factory scissor jack, but supplemented by a Mercedes Sprinter double-ram bottle jack with 25” of lift And a high-lift jack base.
This allows for jacking of the Jeep or off-road trailer at multiple jack points, depending on failure.
PLEASE BRING WHEEL CHOCKS AS WELL. !
Jeep Wrangler JL Changing Tire on the Trail??? IMG_1591
Jeep Wrangler JL Changing Tire on the Trail??? IMG_1592
Jeep Wrangler JL Changing Tire on the Trail??? IMG_0012
Oncorhynchus
Moishe
San Jose, CA
2018 JLU Sahara Sting Gray 3.6L
This thought process started with me realizing that I don't have good jack points for my hi-lift jack on my Rubicon XR with factory steel bumpers and rock rails. It quickly turned to reading a variety of threads where while some are pro hi-lift jack as a recovery tool, but surprised that many MANY are against it as a safety hazard. So after reading multiple articles and countless posts, what I am not clear on is what the recommended way to change a tire on the trail? Do the experienced folks lean towards a repair instead of a tire change as their plan A? Is there some kind of bottle jack that is preferable to a hi-lift? I know I need to purchase some new gear, but not sure if I need a soft shackle or other hi-lift jack accessories to create safer jack points or go in another direction entirely. I've thought I was pretty well prepared, only to find that after thinking through the scenario in detail that I'm not nearly as prepared as I thought I was for a flat tire while wheeling. Thanks all for the input.
I used to carry a hi-lift with the accessory that clips onto the wheels. Dominion Off-road hi-lift mount was very nice. I didn’t like mounting the jack outside the Jeep because the mechanical elements get exposed to more dirt and corrosion. It looks like a simple tool but it does require maintenance.
I realized after a while that my primary need was for something to change the tire, not all the different things that a hi-lift can do. I rehabilitated my injured shoulder so that I could lift a spare 110 lb tire on/off the back of the Jeep by myself. And I went with a scissor jack. Details are in this thread.
https://www.jlwranglerforums.com/forum/threads/my-new-scissor-jack-setup.68147/
GATORB8
CLT NC
Looks like a great setup. To confirm, you have clearance under axle tube at full flat?
Can't remember if I mentioned it before, but I had a partial failure with the stock extension bar at the hook. I replaced with a new OEM, but probably something to think about. The hook istelf yielded and twisted into a corkscrew, was able to finish the tire change and get it back down.
Which brings up another issue. I'm not a big guy, I'm old, with arthritis and my 37s are well over 100 lbs. I can get the spare down, but putting the flat back up on the carrier is a two person job for me. I have an idea to make up a little rope hoist to quickly attach to the Teraflex spare carrier.
GATORB8
CLT NC
I could swear I saw something for this, but I can't find it.
I did find where someone puts a drop hitch in sideways and rolls the tire up on it. Sounds like that may be helpful.
  • Like
Reactions: STW
