Cabin air filter confusion
RDakota
RDakota
Roger
2021 JLURD
How often do you replace your cabin filter? It’s a ’23, you must drive in some really dusty conditions if you already need to replace it.
Ours is a 2021 and I replace the cabin filter once a year.
Clear as mud
Kansas City
2021 Jeep Wrangler Unlimited Rubicon Eco Diesel
I’ve never tried this but… A couple of people in the Jeep clubs here buy these and cut them to fit, and or cut to fit the washable ones. $20 and forever use supposedly.
Thanks man, definitely going DIY for the Cabin filter for sure. Will give it a whirl..
Old Dogger
Cave Creek Arizona
Our 2018 JLR has a one piece filter. $22 at Oriellys.
wcjeep
Earth
YJ with stuff. JL 2dr Sport
How often are you guys changing them?
I have about 25,000 miles and 4 years on mine. Not a lot of off-road, and almost none behind another vehicle in dusty conditions. Still, I figure it's time to change it.
The activated charcoal has a limited lifespan. Charcoal can absorb contaminates. Yours is probably worn out. More important for those with sensitive breathing issues. New cabin air filters with activated charcoal usually ship in sealed plastic. The DIY ideas seam to use non charcoal filters. Probably work great if not sensitive to your surroundings. The correct filters are cheap enough I'll replace with oem style when necessary.
IQ_imbalance
Bob
Maryland
2022 JLU Rubicon 3.0d
I've been using the K&N cabin air filters for a while, fit is perfect and I just take them out to clean twice a year. #VF2064. 2 filters are in the package, Price seems to have increased since I got mine, but then everything else has too.
This is in a 3.0L diesel?
IQ_imbalance
Bob
Maryland
Pulled my cabin air filter; turns out to be the single panel version. Replaced it with this: https://www.amazon.com/dp/B0BCP4MZHC
Was a simple drop in replacement. Only challenge was getting the filter door back on, but that was user error...it goes back on the way it came off (angled toward the passenger compartment).
Probably will switch to the K&N at the next change interval, though.
JLUR Farout
M
SE Washington
2024 JLR X 35" Package
The EcoDiesel 3.0 engine uses a different cabin filter for some reason. The correct part number is 68364653AA. You need two, and they are pricey.
Since they are basically the same as the air filters your home A/C uses, you can make your own for a lot less. Buy one of the "cut to fit" home A/C filters and you can make enough to last for months. I've been using homemade filters for quite a while with no issues, and most of my driving is in the desert so I need to change them often. The approximate dimensions of each filter is 7 5/8 x 4 3/4 x 1 inches.
From the factory my 2023 FarOut came with a one piece filter and the ink used to paint the data on the side was, well, empty, and it is only shadows.
nsfw_andy
2022 Hydro Blue JLUR Ecodiesel
I just changed my cabin filter on my 2022 diesel, also a one piece filter.
Part number is 68565698AA on the filter.
Mdwilmoth
Manhattan, IL
22 Jeep Rubicon
I was at the dealer today and decided to pick up a cabin air filter. I had part# 68535621AA written down as being correct for the 392 version. The parts guy couldn't find a part. Then looking it by VIN he came out with 68565698AA @ $50.00. MSRP is $34. I made him double check.
Apparently in late 2021 68535621AA (now replaced by 683018631AA) was replaced by 68565698AA in the newer model years. The filter I got is about 8x9.5 inches. I haven't installed yet.
Ormond Beach, Florida
Retired at 55 ..
You could have purchased 4 (FOUR) aftermarket cabin air filters for what the dealer charged you for that one OEM cabin air filter.
