Bubbles in Paint at Door Hinges
J. Creeper
Annie
Georgia
2020 Jeep Rubicon
I got my Jeep back today, 3 weeks to the day. From what I’ve seen so far they did a good job and addressed all the spots we discussed. Hopefully the issue doesn’t return anytime soon!
I’d invest in Chemical Guys Paint Sealer. Protect your paint from rust. Seal all nicks and deep scratches with a clear coat pen to prevent further rust issues.
J. Creeper
Annie
Georgia
2020 Jeep Rubicon
Yeah, a paint sealer wont stop galvanic corrosion.
Clear Coat Pen will prevent moisture from getting under your paint if you apply it as soon as you see a scratch is deep, or your door hinge gets chipped from taking your doors off. I’ve used it has worked so far. I use Chemical Guys Jet Seal to prevent moisture damage and protect my paint from fading as it ages.
TheNewGuy
Wes
NH
2021 Jeep Wrangler Sport S 2 door
Much of this corrosion isn't the result of a chip or scratch. It starts in random spots like door and hood edges in addition to the door, hood and tailgate hinges. It's galvanic corrosion, not rust.
JLAFAKASI
Lito
Richmond, VA
JlU Sport S 2019
This is galvanic corrosion because of the aluminum doors and steel bolts. Once it starts it is almost impossible to stop it. If they can clean it all out and epoxy paint the area it MAY stop it. But they absolutely have to put in new bolts! The bolts have a coating on them that helps prevent this from happening, if they re use the bolts it will 100% do the same thing again.
Did you take yours in for repair? If you did, is it holding up?
azjl#3
North AZ
Hey GraniteJLU,
We certainly understand why this may be concerning. We suggest having your dealer inspect this concern, as they are in the best position to provide assistance. We are also available via private message if you would like any additional assistance during that process.
Jeep Social Care Specialist
Hey jeep cares, what is this problem, why are people having so much trouble getting it fixed?
LLRubylady
Lisa
NY
was an ‘18 Rubicon Mojito! now a boring Mazda
“We can certainly understand how this could be concerning.”
Ya think??
I mean people pay on average 40-60,000 dollars for a Jeep that is literally rotting away.
People are mad as hell. And they have every right to be.
JPThing2
JJ
NY
124 Spider, Armada, C8Vette
I wonder if any sacrificial anodes could be used to stop the galvanic corrosion. This is used to prevent corrosion in ships/submarines. Not sure it would work in this situation.
Interesting, because I was thinking the same thing yesterday. Couldn't zinc sacrificial anodes be attached in several locations around the vehicle (under hood, doors, etc)? Should be easy to sand the vehicle in installation spots and attach to put the anode "in the circuit" so to speak. Would cost Stellantis very little as preventative or following repair work.
*Note: I'm no metallurgist and only know a little about these due to boating, but I did stay at a Holiday Inn Express once.
Bill_P
Bill
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
Picked my jeep up at the dealer Thursday and will be dropping it off again Monday. The dealer told me all 4 doors, the hood, and all 8 hinges would be getting painted by their outside contract body shop. Inspected one of the "painted" hinges and it still had corrosion on it. Two doors still have spots as well. They only repainted 2 doors and the hood and guess which 2 doors still have spots :mad:. They already had it for 2 weeks, let's see how long they have it this time.
Ron93YJ
Ron
Pittsburgh, PA
2021 Rubicon 4xe
I drop my Jeep off for paint warranty for the 2nd time on Monday. I have rust on the hood, the door hinges again. and all four doors have some rust on them..
Are you still under warranty or are you covered because you’ve already had the issue addressed before?
wibornz
Ted
lansing, Mi.
www.instagram.com
JL Unlimited Rubicon
Still under warranty. The factory corrosion warranty is 5 years unlimited miles.
