Billy’s Build: Rubi Two
BHo
BHo
Billy
Las Vegas, NV
2020 Wrangler JLU Rubicon Recon
Engineer
Tried a flex test today in the newly lifted Rubicon. Note: I did remove some rear inner fender plastic prior to clear the 37” BFG MTs.
Had to snap a poser pic while airing down to 12psig:
Jeep Wrangler JL Billy’s Build: Rubi Two B6226181-3C73-4562-8A86-FC5AE075EACB
Articulation with full contact at front diver and rear passenger bump stops:
Jeep Wrangler JL Billy’s Build: Rubi Two 391D58CA-4208-4AE2-AFD8-556A1FB39932
Jeep Wrangler JL Billy’s Build: Rubi Two C731C6BA-118F-4AD3-8541-9B74EC84985B
Jeep Wrangler JL Billy’s Build: Rubi Two F62F4D67-39D9-465E-B6FE-CD61FB602321
Rear clearance:
Upper fenderwell of passenger rear.
Jeep Wrangler JL Billy’s Build: Rubi Two 04E96F18-51F3-4A6C-AF95-E7E427457421
Back part of fenderwell after cutting out and heat molding. Measured 1/2” clearance from lower edge of painted metal to OD of tire.
Jeep Wrangler JL Billy’s Build: Rubi Two 450C1075-6D2B-4B42-A0B7-A6A301CFAE08
Creeker
Jim
Hickory, NC
CJ-7, 2020 JLR
Looks good.
Any thoughts on going with aftermarket fender liners (e.g., Artec) to get more flex?
BHo
BHo
Billy
Las Vegas, NV
Engineer
Looks good.
Not in the near future. I’m working on a ABS moldable plastic insert for the rear.
grandsrus
DFW, TX/ Melbourne, FL
2019 JLUR
Aerospace
Rear clearance:
Writeup on this please?
BHo
BHo
Billy
Las Vegas, NV
Engineer
I’ll post my complete writeup once I have all the cosmetics finished up. I bought ABS Plastic to fill my fender trimming. However, here’s a rough picture of its current state with upper lip heat molded back and lower plastic trimmed/removed to accommodate rear tire travel.
Jeep Wrangler JL Billy’s Build: Rubi Two FD54F6D6-89F5-4C50-8D91-D3405C2B7D32
BHo
BHo
Billy
Las Vegas, NV
Engineer
Here’s my writeup on rear inner fender trimming to accommodate 37” tires with full travel to bump stops. I have NO rubbing in the rear after this modification.
_____
I believe the forum is calling this upper plastic heating “Eddie’s Modification”. Smooth out upper plastic with heat.
Jeep Wrangler JL Billy’s Build: Rubi Two 38625ADB-BC55-4119-93F5-9EF073E24C9E
I removed the lower section for trimming. A good pair of Fisker Scissors did the job, but I think a dermal work also work.
Jeep Wrangler JL Billy’s Build: Rubi Two C293643D-CA3A-4F98-8974-20DB9FE4D990
Jeep Wrangler JL Billy’s Build: Rubi Two 546BF4C0-E3B8-46E3-98AA-2DCA687696EB
Jeep Wrangler JL Billy’s Build: Rubi Two E521B8F4-81D0-4D3E-8C81-F877F07A45E8
Jeep Wrangler JL Billy’s Build: Rubi Two 1917F3E1-9912-4A10-9F3B-C70B2B3CC694
I used 2 ABS plastic Sheets from my front bumper order. See that post for amazon link.
Jeep Wrangler JL Billy’s Build: Rubi Two FF990B2B-0A70-4BDB-AB0A-4D30CA3D5DD9
Jeep Wrangler JL Billy’s Build: Rubi Two 57E15E72-0564-4A01-9B47-6EE087C045BC
You can either Plastic Bond or Rivet. I decided the rivet with #10 backing washers, and heat gun worked better after playing with both methods. The Plastic Bond looks much nicer, but I try to follow the 15’ away cosmetic rule. If it looks good 15’ away, I’m happy!
Jeep Wrangler JL Billy’s Build: Rubi Two D7DE0A3A-8175-4628-AA8C-D12B67368A38
Jeep Wrangler JL Billy’s Build: Rubi Two 45CFD584-9565-4AF5-84E8-0D777EA15A4F
I removed the lower section of plastic to drill the two upper holes and used my HI-LIFT to give myself some additional working clearance.
NOTE: I rattle canned all my pop rivet heads semi gloss black after installation. You can purcase black pop rivets.
Jeep Wrangler JL Billy’s Build: Rubi Two ADDF2A6B-2D58-4975-B40E-36BF40C24B02
Jeep Wrangler JL Billy’s Build: Rubi Two 1C587C88-75F3-43A9-B588-4BA43A5A75FB
Jeep Wrangler JL Billy’s Build: Rubi Two CD348C22-032E-4BEF-A509-E2D795B88405
This project was a bit of fussing with plastic and took a methodical and patient approach. I might CAD up downloadable/printable templates and instructions for DIY at a later date. That is assuming people are interested in cheap modifications versus buying expensive aftermarket parts.
grandsrus
2019 JLUR
Aerospace
_____
Yes we are interested, thank you!
  • Like
Reactions: BHo
ALEX-4LO
Alex
No where
2018 JLUR & 2020 JLUR - Project JL's
"Eddies Mod" did not work for my 38" tires, they still rub. It looks like you cut into the bottom of the plastic inner. My tire rubs on the upper middle of the inner fender. I will eventually pull them off.
Let's trail Rocky Gap
  • Sad
Reactions: BHo
BHo
BHo
Billy
Las Vegas, NV
Engineer
Yeah, on 38” mile stars you’re going to need to bumpstop or pull the Inner fender liners. My 37s just (I mean JUST) clear the upper inner fenders.
BHo
BHo
Billy
Las Vegas, NV
Engineer
Found a suiting name for the new rig. Welcome “Grizzly” to my family.
72Blazer
The Real South Texas
72BlazerCrawler 72Blazer12V 88SBDuramax 18JLUR
SLP
Any rubbing on the front? I’ve been wanting to do this mod on my rear inners but not at the point where I want to cut the plastic/ metal.
BHo
BHo
Billy
Las Vegas, NV
Engineer
No rubbing on the front. I did remove the steel bumper wings, tested at full articulation (to the bump stop) and cycled my steering lock-to-lock. I think 13.50”W tires will require A minimal amount more offset, but the 12.50”W tires work great on the MOPAR wheels.
Jeep Wrangler JL Billy’s Build: Rubi Two 39B0DFF9-66FB-409D-836E-3C31CA1ED063
BHo
BHo
Billy
Las Vegas, NV
Engineer
That TJ looked pristine
I’m kinda kicking myself for letting it go, but didn’t want to commit to stretching it and 39” BFG MT mods. I think I’ll find an older CJ7, LS swap, and coil with 39”s.
