nU7OuxIx
On my 2021, I know for sure it happened to the passenger front and the drivers rear, at different times. It's been so long, I can't remember other times, but I know I've been to that tire shop more than twice.I am intrigued by this. I’m not an expert and everyone’s terrain is different.
Although you have removed air to get to 20psi, a lot of people here wouldn’t consider that aired down. Non bead locks being run at 10, 12 or 15 on the high end is common. Has this happened to every one of your wheels at different times? Are you getting stuck and just spinning trying to get out and that’s what is forcing debris between the tire and wheel? Do the leaks happen on the inner and outer edges of the wheels? I believe you, just trying to understand.
On my 2025, it just happened on my driver side rear, but I've only wheeled once with it. I'm pretty sure I wasn't spinning my tires....if I did it wasn't noticeable or on purpose. I know there was a tank trap in one section where most people got stuck, but I made it through fine. I know there were also some large bumps on the trail.
Every leak that I've encountered has happened on the outer edge of the wheel. I've never had a leak on the inside. It's kind of why I feel like I smack something, which lodges dirt in it and the headache begins.
Thanks for the troubleshooting as well. I really need to air down more because there's areas of sugar sand where I get stuck in, but I am afraid to air down more just because of my experiences plus I'm in the middle of nowhere.
