AUX Switches: Cable COLOR CODE Wiring Identification
MauiSteve
Stephen Rodgers
2021 Rubicon 2 door, 2018 Colorado ZR2, 2009 Honda Ruckus, 1973 Honda CB750
Mostly retired
I still need to figure out why mine showed no voltage. Weird
Mitbackwards
Tim
Bay Area, CA
Thx for all the info in this thread.
Basic rookie question, assume you can run multiple grounds on the same point? Wiring two sets of lights (four total) into aux 3 & 4 this weekend and plan to use the same ground point for each set. Any issues?
Rhinebeck01
Ormond Beach, Florida
Retired at 55 ..
Basic rookie question, assume you can run multiple grounds on the same point? Wiring two sets of lights (four total) this weekend and plan to use the same ground point for each set. Any issues?
@Mitbackwards
There is no problem doing that..
Wobblenuts
Matthew
Titusville, Florida
2018 Jeep Wrangler Sport
Lockheed Martin Space
Anyone have issues with any switches not working? They all light up but AUX1 won’t click the relay. I swapped the relay and checked the fuse. Also checked wiring behind the switch. Any ideas?
JayJay
Johnny
North Georgia
'20 JLR
You've checked to be sure that it's configured correctly in UConnect?
aham23
A
Arizona
2021 JLU Rubicon
Can I add more than one LED light to the same AUX switch? I’ve got a 21 JLUR with the Tow/Aux package.
If I have say a front bumper Light Bar and A Pillar Ditch Lights can they both be on AUX 3 or 4? I will have Rock Lights and Rack Lights for “camp” lighting as well.
How do we handle all the lights?
Rhinebeck01
Retired at 55 ..
Your Aux switches are fuse protected at either 15 amp or 40amp...
Aux 3 and 4 are both fuse protected at 15 amp... With that said all the lights you use in regard to Aux 3 or 4 dealing with them, cannot exceed say 12-13 amp...
Just be sure the total amp of all the lights you want controlled by the particular Aux switch does not exceed the amp rating of the fuse... Usually it is prudent to have the total amp draw of the lights to be a bit below the fuse rating..
DO, consider going with LED lighting as they are low amp ....
demisx
Dee
Desert Hot Springs, CA
Wrangler JLU Rubicon
Going back to wiring CB and Ham together. I have Cobra 75 CB (3 amp max on Tx) and ICOM 5d-5100A (13 amp max on Tx). Since the “ignition on power” wire is rated 10 amp only, is the correct way to wire would be:
1. CB power -> “ignition on power” wire in passenger footwell
2. Ham power -> directly to the battery hot through firewall
My understanding is that I can’t wire them both to the “ignition on power” auxiliary wire because I’ll exceed max 10 amps rating, correct?
Revtech100
Dale
Hurricane Utah
2019 JLU Rubicon
I have all 4 switches lighted up but switch 2 won’t power anything up. Fuses are good. Any suggestions on how to trouble shoot this?
Rhinebeck01
Retired at 55 ..
@Revtech100
Is this on a Aux that was installed at the factory or a Mopa Aux kit you installed..
A year or 2 ago on this forum a guy posted he had an Aux switch that lighted up but would not power anything.... and it turned out the problem was occurring because of a cracked connector on the backside of the individual, problematic Aux switch itself.. IF, I remember correctly the guy cracked the connector himself when installing the Aux kit.
Revtech100
Dale
Hurricane Utah
2019 JLU Rubicon
I installed it myself. I’ll pull it and check. Only #2 switch doesn’t work. Thanks!
Wobblenuts
Matthew
Titusville, Florida
Im in a similar situation with switch 1. I can’t hear the relay click when I turn it in.
