AUX Switches: Cable COLOR CODE Wiring Identification
Trek54
Gary
Mt Juliet
2023 Jeep Rubicon
YES exactly as mine were installed at the dealer. I had to change the switch I used on 3 because its actually a 40 Amp fuse. A little confusing because the factory installed switches are different as mentioned in previous posts.
wanderer
Ralph
Carlsbad CA
Engineering Geologist
I am wiring up. 2 off road lights. The question I have is can you join the wires together so that you only have one wire going to the auxiliary wire? Each light has a separate wire or do I have to run both wires to the same auxiliary?
Slammed
Shorewood,Il
2021 JLRU ,2010 Kia Soul
Can anyone point me in the direction to get a 15a fuse to replace the 40a fuses for the factory installed aux switch ? Added some more lights and don’t want them on a 40a fuse
Terrymo
Terry
2023 JLURXR 3.6 ET
Littelfuse slotted mcase I believe. Available from Amazon, Mouser, Waytek Wire etc
Pull your fuse and double check against the info in this thread
https://www.jlwranglerforums.com/fo...-spare-fuse-guide-for-jeep-jl-vehicles.51525/
https://www.jlwranglerforums.com/JL-Wiring-Diagrams/POWER-DISTRIBUTION-CENTER-LAYOUT.pdf
