Audio system issue - cutting in and out
JGoodhue
New Hampshire
2018 JLU Rubicon
My Wrangler JL does not even have 400 miles on it and I just experienced it tonight on my way home from work. (Music cut out and no lines on backup camera. Very frustrating to be having a issue like this on a $54,000 vehicle. Maybe they should not have switched to alpine brand. Had 2 JK Jeeps in the past and still have 1 and never had any issue. Does anyone know anything more? I tried the resets with no luck. I did get a software update from uconnect the other day. Not sure what it was for but I did it. If it was for this issue it didn’t fix it. I share all of your frustration on this matter and they better get it fixed fast.
Mine has 55 miles!! Your part of the club! Jeep should give free KY with every one sold!
RIC3BOY
Canada
2019 RAM 1500 Rebel
Here you go everyone:
From the 5thGenRam forum: https://5thgenrams.com/community/threads/annoying-uconnect-glitches.2098/#post-56420
TSB# 08-091-18 (https://www.dropbox.com/s/lvko1eeesqajou5/Radio and Back-up Camera Enhancements.pdf?dl=0)
Specifically outlines audio cutting in/out. However, this apparently only affects 2019 RAM 1500s and 2019 Jeep Cherokees. This TSB was released November 5 2018, and outlines bringing the software revision to 1828.08.
Sign in
Jeep Wrangler JL Audio system issue - cutting in and out
NUMBER:
08-091-18 REV. C
GROUP:
08 - Electrical
DATE:
November 5, 2018
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system, or
transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of FCA US LLC.
THIS BULLETIN SUPERSEDES SERVICE BULLETIN 08-091-18 REV. B, DATED NOVEMBER
02, 2018, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE
HIGHLIGHTED WITH **ASTERISKS** AND INCLUDE, ADDITIONAL SYMPTOM/CONDITIONS,
AND ADDING A CAMERA LOPS.
SUBJECT:
OVERVIEW:
This bulletin involves updating the radio software level to 1828.08
MODELS:
2019 (DT) RAM 1500 Pickup
2019 (KL) Jeep Cherokee
NOTE: This bulletin applies to vehicles within the following markets/countries: NAFTA,
APAC, EMEA and LATAM.
NOTE: This bulletin applies to DT vehicles built on or before November 01, 2018 (MDH
1101XX) equipped with one of the following radios:
This bulletin applies to KL vehicles built on or before October 15, 2018 (MDH 1015XX)
Uconnect 3 with 5ā€ Display (Sales Codes UAA, UCA or UJA)
Uconnect 4 with 8.4ā€ Display (Sales Codes UAM, UCM, UDM, UGM or UJM).
Uconnect 4 with 7ā€ Display (Sales Codes UAG, UCG, UDG, UJG, ULG or UGG).
SYMPTOM/CONDITION:
Customers may experience one or more of the following:
**Blank rear camera image in reverse (If this is the customer concern use camera LOP 18-60-
02-D3) DT only.**
Audio cutting in and out during memory recall.
Ring tone too loud.
AM/FM volume fluctuates.
While in CarPlay
T
or AndroidAuto
T
Google
T
maps showing wrong location.
Phone disconnected after first call.
Black screen or White screen with vertical lines.
Personal Identification Number (PIN) clears and volume locked while KeySense is used.
Audio static while in SXM/SAT modes.
Echo heard during Bluetooth phone calls.
The radio is locked up.
The radio remains on after ignition has been turned off.
The radio resets.
The radio screen turns black.
Intermittently requires an anti-theft code to be entered.
DIAGNOSIS:
Using a Scan Tool (wiTECH) with the appropriate Diagnostic Procedures available in
TechCONNECT, verify all related systems are functioning as designed. If DTCs or symptom
conditions, other than the ones listed above are present, record the issues on the repair order and
repair as necessary before proceeding further with this bulletin.
If the customer describes the symptom/condition listed above, perform the Repair Procedure.
REPAIR PROCEDURE:
NOTE: An 8 GB USB flash drive is required for this update. It is also recommended to use a
quality, name brand flash drive over a generic USB flash drive.
1. Has a
8 GB
USB flash drive been created?
YES >>> Proceed to
Step 11
NO >>> Proceed to
Step 2
2. Perform the following steps to format the USB flash drive
(Fig. 1)
a. Select ā€œFAT32ā€ format.
b. Select ā€œDefault allocation sizeā€ under Allocation Unit Size.
c. Select ā€œQuick Formatā€ under Format Options.
d. Click ā€œStartā€.
3. Go to DealerCONNECT>Service>Uconnect Command Center>Uconnect>More Information
>Dealer software downloads to download the files.
Fig. 1
Formatting The USB Flash Drive
08-091-18 REV. C -2-
4. If a security message appears ā€œDo you want to view only the web page content that was
delivered securely?ā€
(Fig. 2)
. Press ā€œNoā€ to continue.
NOTE: If the software cannot be downloaded, make sure you have proper security access. If
not, have the Service Manager or Shop Foreman download the software update.
5. Use a blank USB flash drive with at least 8 GB of space. Follow the on-screen instructions to
download the software files.
6. Download the software update file to your local PC’s desktop. Make sure to select the ā€œMACā€
radial button for all downloads
(Fig. 3)
Fig. 2
Pop-Up Security Message
Fig. 3
MAC Download Steps
-3-
08-091-18 REV. C
7. Be sure to download the file to your PC’s desktop and open it
(Fig. 4)
8. Extract the downloaded file to the USB flash drive
(Fig. 5)
NOTE: It may take a few minutes for an accurate extract time to be displayed.
9. Once the file is extracted to the USB flash drive flash drive, it is recommended to label the USB
flash drive with the bulletin number and proper radio Sales Code.
CAUTION! Eject the USB flash drive properly from your PC. Failure to eject the USB flash
drive properly may result in an improper file byte size and cause the update to
not fully download.
Fig. 4
Extracted File
NOTE: The USB should only contain a folder labeled ā€œ18000000ā€ on it after files are
extracted to it.
Fig. 5
Extract File To USB
08-091-18 REV. C -4-
cbournis
Charlie
New York
Jeep Wrangler Rubicon
Just called Jeep customer care.... My Wrangler has the latest software according to them... So they wont let me download this latest version.... Not happy... Why do i need to wait weeks for a service appointment and be inconvenienced for something i can do myself?>??????
JeepCares
Auburn Hills, MI
JL
Hi Everyone,
If you have not done so already, please send our team a private message with your VIN, mileage, and dealer. We would like to document this concern and investigate further.
Darlene
Jeep Social Care Specialist
Gulo gulo
Gulo gulo
Wyoming
Rubicon JL
Having the problem of audio cutting out. Seems related to temperature. Only does it when it is cold outside, but does not always do it when it is cold.
Took Jeep to dealer. They said bring it back when it was doing it.
Brought back next day. Dealer ran diagnostics. Dealer says:
Radio is bad. Jeep knows about this problem, and quit using Panasonic products in early 2018 because of it.
Radio needs replaced. Dealer must get approval from Jeep to replace the radio. Replacement radio - if Jeep gives permission to replace - may take days, weeks, or longer to arrive, and may have the same problem as this one.
Currently in limbo, awaiting call to learn if Jeep approved replacement of the radio.
Pic18
RI
2018 Mojito JLUR, 2017 Grand Cherokee Trailhawk (my wife’s)
Interesting that they quit using Panasonic products in early 2018. I wonder what they use now.
natedoggg101
Nathan
Montreal
Wrangler JLU Sahara 2018
It is not related to cold weather, some ppl in Florida are experiencing it...
Brent
Credit River Township, Minnesota
2018 Wrangler Sahara, 2017 Ford F150, 2010 Camaro RS, 2008 Mazda MX5
I had the audio cutting out on my one week old Wrangler JL Sahara. I followed these steps from the RAM forum, and it fixed the problem.
Jeep Wrangler JL Audio system issue - cutting in and out U Connect
IPvFletch
ATX
JLUSS
Brent, which size screen do you have? I have the 7" and this did nothing. I tried it with the steering controls Phone+VR, and I also tried it again with the Volume/Scan buttons on the stereo. Neither one did anything after 30s, and the U-Connect screen never turned black or appeared to have reset, either. This may not work on the 7" screens I wonder.
Brent
natedoggg101
Nathan
Montreal
Tried it, tried and tried it, again and again and again.... Doesn't work.
JeepCares
Auburn Hills, MI
JL
Hi Rmartinson,
We truly apologize that you are experiencing this. Please send us a private message so we can have this documented and escalated to the appropriate team for further handling.
Lydia
