Anyone else have this under their dash?
wizardfitz
Franklin
2021 Willys
Where exactly did you find it and why were you looking?
McGilli
Richmond BC Canada
2020 Sahara Unlimited Altitude
All good here :)
Wow, all my fuses were seated AND no GPS tracker - I should buy a lottery ticket :CWL:
Jeep Wrangler JL Anyone else have this under their dash? Screen Shot 2021-04-04 at 7.29.20 AM
JeepU4IA
Rod
Los Angeles
2014 Dodge Charger R/T, 2018 Jeep Wrangler JLU
Dryver
NE Ohio
2021 Wrangler 4xe "Bridgette"
Maybe these are how Jeep tracks the units to the dealers to provide delivery ETA'S. 😲
Jhint77
Jhint77
Jason
Colorado Springs
2021 Unlimited Rubicon Sting Gray
A&P Mechanic
Under the dash connected inline with the OBD2 port.
I was installing a "dead pedal" and noticed a harness hanging down. After investigation well... here we are.
danm
Philadelphia
2020 Jeep Wrangler Rubicon 2-Door Sting Gray
I’ve gotta go check my Jeep now. This is creepy stuff here.
Jeep Wrangler JL Anyone else have this under their dash? EF1BB009-E9B9-433C-869F-7333F9A76E9D
Showinoff
Bryan
Iowa
2021 Rubicon
I was reading this thread from the beginning and recognized the part in the photo from when I was installing my CB. Thats how I found it.
gm920
Gary
San Diego County Mountains
2019 Jeep Wrangler JLUR Billet Silver
Aircraft Maintenance Technician (Retired)
Found this under the dash today. Only had the Jeep about 2 weeks. It connects inline with the OBDII port.
Anyone else found one? Should I put it back? Put it in the neighbors car?...
Here is mine, found it when installing my Taser JL Mini, tucked in above the Data Link connector. And tapped into the power wire for it. Not too concerned about it, I think it was no longer activated.
The other thing I found today mounted to the bottom of the center panel below the steering wheel, while installing my Dual Front Trail Cams is the push button thingy with the pull out contact, it has a 3 wire connector. Wiring goes into the center console area, haven't tracked it to its destination yet. I think it has something to do with the tracker, just not sure what it purpose or function is.
Jeep Wrangler JL Anyone else have this under their dash? IMG_3080
TheConquerorWorm
Rusty S.
Massachusetts
Toyota Tundra, ordered ('21 JLUR)
Trouble Maker
I ripped away part of my Tundra's driver side trim and all I could see was a couple of harnesses to the OBDII. I thought I felt a fuse but it ended up just being a wire connection. One harness leads to the airbag under the wheel, and the other ran off to the firewall. Maybe it's a JeepThing™.
gschones
Gary
2018 Wrangler JL Unlimited
It is more than likely related to Jeep's version of "on star" I have it in my 2021 Wrangler. The good thing is if you have an emergency and you are in the middle of nowhere help can find you. If you ever need it you will be glad it is there.
ddorrer
West Virginia
2009 JK
What if you bought the Jeep outright. Would that be a privacy violation of some sort if the GPS tracker was left working in the Jeep?
