Air up/down all 4 compressor system.
LT1Chevy210
2021 JLUR Ecodiesel, 2023 JL 2.0L, 2019 Duramax
I've been using a Viair 450p for the past few years and just decided to upgrade to one of the 10.6 cfm chinese compressors. I went with the EZ Flate and also ordered one of their 4 tire hose kits (definitely could have made my own for much cheaper).
I tried it out tonight and am quite happy with the speed increase. The times below were on 33" KO2s, 37s will take longer but still happy with the improvement.
38 to 15 psi: EZ Flate vs. ARB Deflator
2:50 for all 4 tires vs. 1:05 per tire
15 to 38 psi: EZ Flate vs. Viair 450p
5:45 for all 4 tires vs. 4:30 per tire
Johnson1070
Bob
Mattawan, MI
2023 JL Willys 3.6, 2019 Cherokee Trailhawk
Service Coordinator
I started assembling a shopping list on Amazon last fall. Added multiple compressors and waited for a good sale price. Finally got this All-Top for $135 and built my own 4 tire system for around $125, again with Amazon junk...but it works quickly and well!
roaniecowpony
Retired Engineer
Did you end up upgrading the cables and any other electrics on the compressor, like some videos?
roaniecowpony
Retired Engineer
No Sir, used it as is came. Only a few times so far, but no issues at all.
I have a 10 cfm I got for about 100 bucks, but haven't used it. I'm still using my portable Viair 440P. I also picked up a ARB dual clone. I think it's made by the same China company that makes ARB, based on the kit components and the packaging. Even the box looks like the ARB. Thinking about an onboard setup. But also thinking of selling the jeep.
RicRecon
Ric
NorCal
2021 JLUR 3.0, 2021 JT Overland 3.0
So does anyone run a 4-tire inflate with any of the Viair models? I know twin compressors are preferred but it looks like a 400P, 440P, or 450P would still perform adequately on typical 35s, admittedly slower.
im currently running a MaxiTrac with a 4-tire deflate I made and it works fine. But I’m looking to move it onboard and I would like something smaller in size.
Murphydog
Seattle
2020 X3M, 2023 JLUR XR
I think I have the 400p, use it with morrflate on my XR with the stock 35 inch KO2 tire. Never measured the total time but it doesn’t seem excessive to go from 20 back to 35 psi.
roaniecowpony
Retired Engineer
I run a 440P with a 2 tire hose for 37x12.5 tires. Works pretty well. The 440P has the highest output of the Viair singles, from 10psi to 30 psi. Compare outputs at the psi range you inflate in. The output at 100 psi means nothing when you're inflating a tire to 30 psi. Yes, the hose, inflator, and air chuck that comes with the 440P is crap and can't flow as much as the compressor can put out. But most of us toss that and convert the fittings on the compressor to US standard fittings and a hose system of some kind.
I know a friend has a ARB twin that has a 2 tire system that can air up slightly faster. The ARB is more compact and mount friendly. So, I bought a ARB style clone on Alibaba for what a Viair 440p costs. From what I can tell, the maker of my clone is the maker for ARB. It comes with the full onboard wiring kit that you get with the ARB. I haven't mounted it, since I've had a lot of other things to fix on my JLUR. The options for mounting run from under the hood, under the seat, in the back cargo area, or to under the floor. Under the floor is a bad idea because the first time you go through water, it's flooding the compressor. Under the hood is very hot. So, that leaves the cabin mounting. Message me if you're interested in the Alibaba clone route.
RicRecon
Ric
NorCal
Cool, thanks for confirming this.
dlong1119
Gainesville, FL
21 Sahara 4xe (StingGray)
Not a Viair but using my Vevor single with my home built 4-way kit it takes about 4:45 to go from 18-30psi on my 35s. Compressor was modified with a cutoff swith and standard US style air fitting.
RicRecon
Ric
NorCal
Appreciate the response. I’m thinking about mounting in the cargo area along one side or the other. Probably the passenger side between rear seat and roll bar. I’ve seen a couple ARB clones and probably should consider those too.
RicRecon
Ric
NorCal
Which Vevor did you get? I’ve seen those.
