Air up/down all 4 compressor system.
F4Flyer
Littleton
2024 Rubicon X
I assume the ARB Twin can be used to do 2 or 4 tires at a time- is that correct? It would take longer than a 10.6 CFM like the MORRFlate (my # 1 choice) but I want it mounted on board and not portable. If the ARM twin can do at least 2 at a time, I'll look for sales during Black Friday and also pick up a mounting bracket.
THAW
Foster
23 JL4DrRubicon
I assume the ARB Twin can be used to do 2 or 4 tires at a time- is that correct? It would take longer than a 19.6 CFM like the MORRFlate (my # 1 choice) but I want it mounted on board and not portable. If the ARM twin can do at least 2 at a time, I'll look for sales during Black Friday and also pick up a mounting bracket.
The ARB twin can definitely do 4 (or more) tires at a time.
Whereas, some of the 10+ CFM compressors can burn out if only connected to 1 tire.
DarthAWM
Mick
Odessa, TX
2021 JT Rubicon
Oilfield Dispatcher/Semi-Professional Adult Film Star
I run a Milwaukee 2 gallon compressor and a Speedflate 4 tire system run everything off the tailgate on the Gladiator takes 5-10 minutes to air back up, not bad when I usually need to hit the head, and walk the dogs after a ride.
Rubenmora1
Ruben
Ontario CA
2023 jeep JLUR
I’m running a morrflate ten six with their 4 way hose set up and cost around $400 for the whole thing. And I ended up hardwiring it into the trunk cargo space with the adventure lab cargo mount and their remote kit. I’ve compared it to a dual arb and I filled up all 4 faster. I use the hose to deflate aswell. Faster than doing 1 tire at a time
F4Flyer
Littleton
2024 Rubicon X
I guess I coudl also use one of those regulator things to deflate the tires as well. I do have the Apex Design valves now so deflating only takes a few seconds but would be cool if I cold do the deflating with a regulator of some sort
Medsker
Jon
South Jordan, Utah
Retired Engineer
I just bought these five things and put them together:
Link 1
Link 2
Link 3
Link 4
Link 5
It hooks onto the APEX valve stem perfectly. This makes it nice to see what pressure you are at when deflating.
F4Flyer
Littleton
2024 Rubicon X
That is awesome. Thanks! I got just one valve like that from MORRFlate. They seem identical.
