JSFoster75
- Scott
- Oct 6, 2019
- Bluff City, TN
- 2019 JLUR (Mojito), 2022 JLR (Tuscadero)
- Vehicle Showcase
- 4
awesome write up, thank you for taking the time to put this together.Here are the parts I picked up from Amazon.
16 Gauge Automotive Wire - 4 Roll... https://www.amazon.com/dp/B07QK119BQ?ref=ppx_pop_mob_ap_share
Twidec/8Pcs SPST Round Dot Rocker... https://www.amazon.com/dp/B07W4HGMZS?ref=ppx_pop_mob_ap_share
Install Bay 89-00-9031 ABS... https://www.amazon.com/dp/B0007WTF02?ref=ppx_pop_mob_ap_share
Uxcell a13052800ux0615 600V 25A... https://www.amazon.com/dp/B01AHJV98A?ref=ppx_pop_mob_ap_share
GOOACC 6 Pack Automotive Relay... https://www.amazon.com/dp/B01M74X0ZK?ref=ppx_pop_mob_ap_share
6-Way Fuse Box Blade Fuse Block... https://www.amazon.com/dp/B07HDZVW3P?ref=ppx_pop_mob_ap_share
Manual Reset Fuse, DROK 100 Amp... https://www.amazon.com/dp/B07QJ3XQ4P?ref=ppx_pop_mob_ap_share
WindyNation 4 Gauge AWG (3 Feet... https://www.amazon.com/dp/B01N5O8PH1?ref=ppx_pop_mob_ap_share
Nilight 60001F-B Bar 2PCS 18w 4"... https://www.amazon.com/dp/B00IY3YLCI?ref=ppx_pop_mob_ap_share
Nilight 2PCS 18W 1260lm Spot... https://www.amazon.com/dp/B00G620ZVU?ref=ppx_pop_mob_ap_share
100 Feet 1/4" Split Loom - Tubing... https://www.amazon.com/dp/B00KW9PQTE?ref=ppx_pop_mob_ap_share
I had no clue how to do this when I started.
I got some help from the guys on this thread, https://www.jlwranglerforums.com/forum/threads/diy-switch-pod-for-jl-wranglers.37928/,
Watched some YouTube videos
And
And did some research on Google.
You can just buy one of those spods for $200 and up but I learned a lot by setting it up by myself.
I drew up a diagram to get an idea of how to set it up.
I switched out the blue wire for red just like in the YouTube video for the relay.
I hope this helps. There's more than one way to do things so feel free to change it up or buy other/cheaper parts.
I bought a heat gun from harbor freight and rotary tool kit or use a Dremel if you already have it.
Used these items to cut and shape out the plastic, and heat gun to bend it to shape.
I copied the shape of the cubby onto the plastic with a sharpie. I didn't want to put any screws where the switches are for that face plate so I used a glue gun.
Run the wires through the passenger grommet. It's a pain so I cut a slit on the outer layer. I left one wire to pull wire through if necessary in the future. Don't want to fish that through again.
I hope this makes sense but it's after midnight and I'm sleepy. Let me know if you have any questions and I'll try to help.
