4x4 shop changed my diff fluid differently
Jeep Junkie
Muhammad
Seattle, WA
2024 JL Wrangler Willys
Guys, in the YouTube videos they just drain and fill it. But my 4x4 shop opened the pumpkin, cleaned it with brake parts cleaner, put it back on and then filled it with fluid. I'm confused 🤔
X35
PA
2025 Wrangler Willys XR
I only use brake clean to clean off the cover. From there I’ll use a rag to push out the remaining fluid from the bottom of the axle housing. I’m not a fan of spraying brake clean near the ring and pinion gears and bearings as the potential to force dirty fluid places you don’t want it is high. As always, only my preference, YMMV 👊🏼
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
But is it necessary to open it? Why not just drain and fill?
X35
PA
On my ‘25 Willy’s M210 front and M220 rear axles you must remove the covers as the drain plugs have been eliminated. Crawl under your Jeep and look for drain plugs on the bottom of the axle housing under the differential area. If no plugs then the only way to get the fluid out is pulling the covers. I believe the change to no plugs was made with the ‘24 model year.
BXFXJeep
Toronto, ON
2021 4xe Sahara
I think some assume that is what you want done, my new mechanic was going to do the same.
He told me that is what he was going to do when he quoted time, and price, I said I just want it drained, and fill, he said ok, he also adjusted the price down accordingly.
PatrickIvan
Patrick
Simcoe County, Ontario, Canada
2019 Jeep JL Unlimited Wrangler Sahara
Did you get a quote first for the service asked for? That sounds a little more expensive than a simple drain and refill.
I suppose it depends on all the facts associated with how this came to happen. What you asked for. What they said they would be doing. What the time and cost are.
How old is the Jeep and what are the miles on it to warrant a fluid change versus that kind of inspection service?
If it's your first Jeep / 4x4, then it's an understandable "mistake".
X35
PA
This is fine if your axles have drain plugs. The newer ones don’t, so the traditional cover pull and refill applies.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
He did it as part of the regear job.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
I have the 2024, so this means that the fluid change is not easy for a rookie like me ☹
X35
PA
OP, it’s easy. Remove the cover and let the fluid drain. The gasket is re-usable. Clean the cover and get the residual fluid out of the axle housing without spraying brake clean or compressed air around. Bolt the cover back on following the tightening sequence and torque specs. Re fill with fluid until it runs from the fill hole. Crack a beer, you’re done.
Then go do your transmission like the guy in the video you posted.
Jeep Junkie
Jeep Junkie
Muhammad
Seattle, WA
CptFloridaMan
Gabriel
Orlando
2018 JLU Sport 2.0
I think my 18 also has a drain hole but if it’s there I’ve never used it, I always take the cover off, take a gander and fill er’ up again
bjm00se
JLUR 6sp ordered 11/3/21, picked up 8/30/22
So, I *think* what you're talking about here is the first diff fluid change done roughly 500 miles after a re-gear.
In which case it is entirely appropriate as part of that fluid change to pull the cover and inspect the new gears to check the wear pattern and make sure they're breaking in properly. I wouldn't trust a shop that didn't do that.
