Zandcwhite
- Zach
- Sep 4, 2019
- Patterson, ca
- 2019 jlur
It is hard to beat boost at altitude for sure. Odds are the next Jeep will be fully electric and altitude won't mean anything anymore.It's all about the tolerance and the use case. You would have been fine with 5.13s or 4.88s with the 39's on the 2.0T--especially with a ZF8.
You seem run your Jeep much faster than most on the highway so you need a higher gear to keep the RPMs where you like it--provided the engine can produce the torque needed. My 3.6L at 7K ASL would not and so I was either dragging out gear shifts or staying in lower gears for far too long.
No longer an issue for me now that I have an engine that can produce the torque needed. It was such a pleasure driving through Raton Pass up to COS and not having the transmission up and downshift countless times and flat-out struggle. The boost went up and down, but the transmission did not--problem solved (for me).
