Dr. RGB
- Ryan
- Aug 25, 2020
- Leesport, PA
- 2025 JL Willys 2-Door
- Occupation
- Professor and Shrink
My JL would stumble around 2,000 rpm with a steady throttle. Since I switched to 90 Ethanol-Free, I have had no problems at all.The 3.6L has a very high compression ratio. FCA are trying to control the consequences of that with electronic wizardry. Their software and electronics just do not get it done with 87 octane. On 87 and even on 89 octane when there is some 87 left in the tank, mine consistently stumbles at 1300rpm whether warm or cold. And it is down on power on the highway such as long steady climbs - mine has 35's, so 6th gear is useless on low octane gas. But when I hit a brand like Shell that carries 91 octane, it is perfect. As a result, when I get gas elsewhere, I have to put half 89 and half 93 in which is a pain. Interestly, mine does not seem to benefit from unlimited octane - 93 seems to be more than I need. But 91 does the trick, so that's what I run. Wish I could get away with cheaper, but engine just does not run as well.
