2020 JLUR Locker Replacement
gbr
Gerald
Canada
2020 JLUR
I had my diff gears changed to 4.88 recently. While taking off the main bearing (on both diffs), the guy bust them up pretty good. No biggie, got replacements and done.
Unfortunately, he left some busted up pieces in the rear diff. The gears seem to be fine, but the actuator looks broken (I'll be able to test when I get my Jeep back from service). Apparently, you can't get them separate and have to buy a new diff, gears and all.
So now I'm thinking just replace the lockers (thinking Ox or Eaton). Is that doable? Is there anything else I could do here?
ps: The guy that did the work may not cover this under warranty.
Jeep Wrangler JL 2020 JLUR Locker Replacement diff1
Jeep Wrangler JL 2020 JLUR Locker Replacement diff2
Jeep Wrangler JL 2020 JLUR Locker Replacement diff3
CarbonSteel
What the...? Was this a reputable shop or someone's garage? Since he "busted them up pretty good" and "left pieces in it", how can this not be covered under his warranty?
word302
Oregon
JLU
Exactly. If buying a complete axle is currently the only way to remedy this that’s what they would be doing for me.
asuperheat
08 JKU, 21 JLUR 392
Yeah that's ridiculous, he did not have the correct tools if he could not pull the bearing's. If not the correct tools probably not the experience or knowledge either. I'm guessing this was not a shop and if it was it was a bad one.
I have used Eaton in the past. I now run ARB's. If not factory lockers I personally would switch to air from past experiences I think you will be better off if you use them. It wont be cheap.
gbr
gbr
Gerald
Canada
2020 JLUR
Done by a reputable shop. Used to be the go to shop for gear changes up here. There have been issues recently (which I didn't know), and mine is the icing on the cake. The local Jeep club and shops will no longer be recommending this guy.
The shop owner told me if he warrantied the repair, it would put him out of business... says he was hit hard by the pandemic. I'll be getting something out of him, but he won't be touching my Jeep ever again, or anyone else's if I can help it.
I can't tell you how furious I am.
gbr
gbr
Gerald
Canada
2020 JLUR
I even have him recorded as saying he might have left some pieces behind. He didn't completely clean everything either, there was definitely old oil in that diff when we pulled the cover.
CarbonSteel
I am no lawyer, but it sounds like a legal case in the making. No slight against you, but did you vet this guy at all before giving him your brand new Jeep to undertake a task like this?
This all sounds so half-assed and home garage based. Your situation is infinitely more complicated due to the fact there are no repair parts for the locker mechanism in the Rubicon axles. You are looking at $$$$ to even bring this back to stock.
JimLee
'19 JLU
You won't be able to run aftermarket lockers from the factory locker switches, but you can run them from the aux switches.
Edit, apparently Z Automotive has a fix for that, see below.
  • Like
Reactions: gbr
gbr
gbr
Gerald
Canada
2020 JLUR
This guy has been working on club Jeeps for years. I found out (after the work was done) that he lost his mechanic and hired a new guy. The old mechanic is the one that had done all the previous diffs.
I'll be getting something out of this guy, whether it bankrupts him or not.
gbr
gbr
Gerald
Canada
2020 JLUR
Thank you!
CarbonSteel
Finger and toes crossed--that is a major snafu. Hope it works out for you.
dlporter
PNW
2020 JLUR
To my knowledge, ARB is the only aftermarket locker available for the JL rubicon. The catch is that it requires 35 spline axle shafts. The next catch is that RCV is the only company that makes 35 spline front axle shafts that I’m aware of. RCV = $$$$. The third catch is that nobody makes 35 spline rear shafts for the JLUR and ARB locker.
