Locker sensor bypass for 2020 JLU
JerBear1967
Jerry
Mississippi
2020 JLU Wranger
Hello, I've ordered 2 locker bypass harnesses to bypass the sensor in my rear differential. The light came on and after servicing the front and rear differential, I decided to buy the bypass harness. I bought 2 different ones and tried both off of Amazon and neither fit correctly in the harness plug. to the original. Can anyone recommend a source other than Amazon where the harness actually fits a JLU? it's odd because on Amazon you can buy a $22 one or a $300 one but they look the same. Any help is appreciated. The part is labeled as Z-LKR-OEM.
JerBear1967
Jerry
Mississippi
2020 JLU Wranger
yea, I saw that one but I'm concerned it's going to be the same issue as the other two I bought that don't fit the wire harness from the computer...
fczabala
FL
JLUR; X5
the amazon ones are “known” to have slightly different connectors and you have to “mod” them to fit correctly
the one from z automotive requires no modifications, I have them and plug in perfectly
WannFly
Priyo
Atlanta
2021 Rubicon 4Xe, 2026 MOAB
Cyber security
JerBear1967
Jerry
Mississippi
2020 JLU Wranger
that's what I needed to hear! thanks!
Northridge4x4
Summit Sponsor (Level 3)
Silverdale, WA
www.northridge4x4.com
2016 Sahara JKU, 2013 Rubicon JKU
Seller of badassery
^^^Yep, what @fczabala said above^^^
There is a lot of copycat stuff on Amazon that doesn't fit or work like the real stuff does.
If you are looking at a $22 part that is supposedly the same as a $300 brand name part, you are probably getting a copycat/ripoff part that isn't going to work as good as the original.
